Results 1 to 13 of 13
    Jul 2016
    RI
    Default Control Arm (A Arm) bushings
    Hey all, last night will I was doing a little clean up on the spyder I noticed the front right fender that goes over the front right tire was moving. I traced it back and it is the upper control arm rear bushing. This is very surprising to see, seeing that the bike has 5k on it. Has anyone replaced these? do I need to take the front end off? I don't believe so but I was annoyed about it last night so I didn't go digging into just yet, were there issues with these or were they upgraded in 2014? like I said very surprising, the bolt was tight enough but there was still very obvious movement in and out.
    Sep 2014
    USA
    warranty? since you stated you only have 5K on the bike.
    Jul 2016
    RI
    bike is too old I believe...it is a 2013. I have not read much on them going bad or that they were improved for 2014. Anyone read anything about that or have done these? The top control arm rear I think I will be able to get off but the front looks like they have the bolt going in the wrong way and either the frunk has to be taken off or bolt cut....HOW DUMB! how the hell can control arm bushing be bad in 4k, crazy stuff! the bushing which is just a sleave is 12 bucks a piece which is a total rip off for a bolt sleeve that is 1.5 inches long.
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I posted a very similar problem with mine a couple weeks ago, nobody responded that they had done it themselves. I have 27k miles on mine.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    washington state
    If you can replace might as well do it.
    2012 Spyder RT SE5 Brake pedal mod
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Default A Arm Bushings
    I replied on the other thread. It is very easy to replace the bushings. Jack up the Spyder to get the wheels just off the floor. Do one A arm at a time, remove the bolts(15mm). You pull the metal spacer out and pop out the plactic bushings( they are half bushings). New ones are about $14.00 each. You will 16 to do all 4 A arms. You will need to drop one bolt out of the shock also. Prts break down here.http://www.can-ambrpparts.com/oempar...spension-front I have just got done rebuilding a 2013 crash project with full frame replacement. Did bushing after assembly as they weren't in yet.
    Jul 2016
    RI
    spyderjerry, quick question...is it the metal sleeve or the two rubber spacers that go bad...the spacers are 2 bucks each the metal sleeve is 14. sorry but I thought you said the rubber spacers were 14....just trying to clarify to see what I need to order. the front 15mm can't pull out without hitting the frunk...hope I don't have to cut that one and then just put the new one in the other way.
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Default The Frunk
    is very easy to remove, just 6 bolts and some electrical plugs to disconnect. This opens up the entire front end and makes access to things much easier. This is also a good time to wrap the exhaust headers as they are very exposed.
    Quote Originally Posted by mavrik View Post
    Jul 2016
    RI
    ok thanks much....side panels off, then frunk....
    Aug 2013
    SF Bay Area
    I learned that these bushings need to be greased often. I use a grease gun on the dirk fittings and check them when I do an oil change.
    2021 F3 Ltd , Magna Red
    Sorry Flamewinger, I hadta laugh at the thought of getting in there to fix things with a dirk, and I'm really not just being picky; I'm happy to accept that it could well just be a typo or auto-correct issue, but I hafta say it....
    A DIRK fitting is something fitted to a small knife; while a ZERK fitting lets you grease a bush or ball joint!
    I don't think any of the Spyders came with Zerks on the 'A' arms from the factory after 2013....
    Aug 2013
    SF Bay Area
    There are four zirk fittings on each side where the A arms mount to the frame. (I did mean zirk/zerk not dirk) I had to get an L nozzle for the rear ones.
    This is one of the grease points on my 2013 ST.
    (this is is a zirk/zerk fitting)
    Jul 2016
    RI
    well looks like the control arm bushings...will have to be done...tightened them up hoping that would cure all because they were loose BUT a few miles (ok few thousand) they are both moving when I brake. SOOO bushings and sleeves order...will get into it ...oh fun!
