Results 1 to 11 of 11
    Jul 2017
    Florida
    Default Remove Tupperware for shock replacement?
    I have new shocks coming tomorrow. Will I have to remove any of the tupperware to access the upper shock bolt?
    May 2017
    Mesa, Arid-Zone-A
    No. There are many discussions and some very good videos about this in this forum.
    Semper Fi
    Jul 2017
    Florida
    Quote Originally Posted by canamjhb View Post
    I have searched both ST forums for a how to on this subject with no luck. If you could provide a link that would be great.
    I have seen this but it for a different body style:
    Active Member Samson's Avatar
    Aug 2016
    Prescott Valley , Az
    I just changed my 2016 F3 T to the Elka's. If your hands are smaller there is no problem accessing the upper shock bolt. I struggled with both uppers but finally was able to work through it. The lower bolts no issue at all. Good luck,
    Oct 2015
    Lynden, WA
    Thumbs up STShock Bolts
    I installed BajaRon shock adjusters on my 2013 ST-S.
    Had to take the shocks out to perform the installation.
    My hands are XL and I had very little trouble getting the top bolts out of the bike.
    BajaRon has great installation instructions for the shocks.
    As I recall the trick with installation of the top bolt is to install it backwards.
    No tupperware needs to be removed.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    May 2013
    Edmonton Alberta, Canada
    Quote Originally Posted by scubadown View Post
    What model Spyder do you have? There's a different answer for each model...
    2014 RT-Ltd , Cognac
    Default UPPER SHOCK BOLT
    [QUOTE=scubadown;1301786]I have new shocks coming tomorrow. Will I have to remove any of the tupperware to access the upper shock bolt?[/ .................................................. .If the ST is similar to the RS ... you can remove the panel above the shock and this will give full access to the shock .... Panel removal is very easy .......... good luck ..... Mike
    Jun 2010
    Las Vegas
    Like Haze said reinstall the top bolt backwards. Ron has a trick where you use double sided tape on the nut then start the bolt and pull on it to stick the nit to the frame. Then you don't have to worry about dropping the nut.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Here's the thing....
    It is easier if you pull the two center panels. Also if you remove the forward bolt on the rectifier and loosen the rear one so you can swing it over to get the upper left bolt out.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2017
    Florida
    Thanks for the help everybody. Replaced the shocks yesterday. I found it easier to just remove the tupperware and have easy access to the upper shock bolt. Also while in there, I lubed the four zirk fittings. I like my new Fox shocks.
    Default SHOCK REPLACEMENT
    I love knowing stuff about our Spyders ( all spyders ) ....and I suggested removing the Panel that covers the Top of the shock ( only that one ) ...... so how many panels did you have to remove ???? ........Thanks .... Mike
