bearing cap
I have a 2016 rts and cant keep the inside LF wheel bearing cap on anyone have a fix ?
silicon
some folks have mentioned silicone to hold the cap on ...
I can't pull mine off because I anchored them with RTV slilcone (black) almost three years ago and both of them are still on solidly. If I remember correctly there were three or four clip anchors molded onto the caps that fit in holes in the wheel hub assembly. I gobbed the silicone on each of the tabs before putting the caps back on the hubs. If you have broken tabs that may be part of the problem.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
first one
just lost my first cap left front now that i know it is a problem will fasten on in some way.
Both of mine are gone so no need for me to worry about losing them.
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
Will it ever stop--NO
now !
