Bruce
2014 RTS-SE6
Tri-Axis Handlebars
Sena BT Dongle
Sirius Radio
Dash bar
Show Chrome Trunk Rack
"You know that a politician is lying if his lips are moving"
First charge of "BS" type battery - using Battery Tender?
OK.........Please.....Just to clarify for me.
I've read most everything I can find about buying a "BS" type battery and how to bring it up to 100% charge. All the instructions seem to involve varying current flows and times, but I don't seem to see any clear answer to my question - "Can I just hook up a Battery tender (or equivalent brand unit} to the new battery after filling it with the acid, and let it set a few days.......then install and be 100% good ??
Help appreciated. Note: My current battery is 2014 that was installed when RTL was new. Got 20,000 miles on Spyder now with no indication yet of any issues, but I want to be ready. I do put my Battery Tender on it periodically over "winter", which in Washington is anybody's guess on how long :-))
to utahpete
Originally Posted by UtahPete
This is the first time on this thread you have brought up the term 'BS type battery'; it wasn't part of your original question. Not sure what you're asking now.
Uh Utahpete......my post (from Teninospyder) is a new one from a new person. I wasn't the originator I think you are referring to in your quote (?)
I believe the BS refers to the last letters on the battery number which indicates bottle fill yourself and not the factory fill.
As far as battery maintainers, I also have used the Schumacher maintainers [$40.00] and they work but also use the Harbour Freight maintainers [$6.00]
at the time for over 12 years. I use them for my motorcycle, quads, snowmobiles etc. and have had the batterys last 12 plus years. In Canada Princes Auto sell
them [$9.00] and also one of the biggest battery supplyers in Saskatchewan sells them and highly recommends them, They are called a battery float charger and maintainer, they maintain the batterys @ 13.2 volts with my own voltmeter. I am not trying to degrade the more expensive ones but have had just as good luck with the cheap ones and I have about 12 chargers running all the time. Just my opinion.
Roger
For those that may be still using an Odyssey PC680
At one point there were quite a few members using it. The Deltran won’t to the job.
http://www.spyderlovers.com/forums/s...l=1#post300889
Since I had the Deltran at the same time as the Odyssey tender, I placed the Deltran on first, and once there was the green light, I placed the Odyssey tender on, and it was 1 or 2 lights short of the green.
First of all don't put the acid in until you need to use the battery. It probably will be somewhat charged so a good maintainer will bring it up to full charge in a day or two.
Yes. Another case of excessive and unnecessary worrying.
You will need to get an AGM battery, either already filled or "fill and seal yourself".
Any name brand automatic tender type charger will work......to bring it up to about 95% of it's total capacity and that is PLENTY.
That will probably only take about 24 hours.
If the charger does not have some kind of indication that the charge is "full" then it isn't the right kind.
Battery Tender 101
Originally Posted by oldguyinCT
I have used the "Battery Tender" brand for years. I plug it into the rear top trunk 12 volt outlet, which is always hot as I switched the fuse. My spends about 6 months of any given year in my garage on it, and it has never failed to start right up every spring. And this on the original battery. So that's where my vote goes.
x 2. I have four hooked up. One for the riding lawnmower, one for the Vulcan, and one on each Spyder.
They will be sleeping until March or so. Have always started on the first try.
I too have swapped the fuse to use the plug in the top trunk 12 Volt Outlet. It is very easy to use. I use a Trickle Charger (Battery Tender Brand) - 100 mA.
I just plug the charger into the outlet once a month for 24 hours. Haven't had a problem since my first Spyder in 2008. Now on number 3 <and LOVE IT>
I live in Northern Ontario
I have a Schumacher and a Deltran Jr. both are tenders and work great.
Set up the charging circuit with a SAE plug tied directly into the battery.
David C
2016 F3T
Battery tender cable
Rear IPS Pack Rack
Has anyone used a solar charger/tender? I don't have a garage as such, and the mower and Spyder are in the separate car port with no convenient power. Not concerned about the Spyder, rarely a week goes by that I don't ride, but the mower sits a good part of the year.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
