Results 1 to 9 of 9
    Jul 2016
    Navarre,FL
    Lightbulb Tire Recommendations?
    A friend is needing a new rear tire. We need it put on by Tuesday or Wednesday. Any recommendations on what are the best ones?
    Houston
    Quote Originally Posted by Ms Noles View Post
    We stock and install the Yokohama S-Drive on the rear of all model Spyders. Great tire and readily available.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Default GREAT TIRE
    You should be able to get a General Altimax RT43 in 215/60 -15 ... look on-line ( E-bay ) click Free shipping and lowest price ..... If you enter the EXACT tire you want ( see above ) it will save you a lot of search time..... a Michelin Premier AS .... in a 205 size... will be a bit more expensive ..but also a great tire .... Mike
    Active Member SpyderNeil's Avatar
    Jul 2015
    Kamloops B C
    I put one on my F3T 4,000 Kms ago and the S-Drive is Great. Virtually the same width and diameter, so it won't change your speedo or upset the Nanny.
    Neil
    2020 Harley Davidson Tri Glide Ultra
    2017 F3-T SE6 White / BRP Backrest / Nuvi 58 LM / Polaris Spring Spacers / CALSCI 22" Shield
    2016 RTE6 , Black
    Vermont
    What tire size is your friend looking for?
    What spyder model does your friend have?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Nov 2013
    Oro Valley Arizona
    Mr search or should I say Advanced Search is your friend here. (Upper R/H corner) Look up and to the right! There are literally thousands of opinions
    and many different brands including the OEM.
    Seriously, let's get on with the more important things here, like where do the better looking older women hang out!
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Dec 2008
    Jacumba, CA
    Last Thursday I had 3 new Kumho tires installed. 155/60/15 fronts and 205/55/15 rear. They are beyond awesome. No drifting in the road groves, stays right on track in twisties, VERY quiet, etc. Hard to believe.
    Bought them from Tire Rack, for around $289 delivered.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Nov 2012
    North Las Vegas, NV
    Central Florida Power Sports has good tires and can install them.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Houston
    Deanna
    All Spyders use the same rear tire size.
