Results 1 to 17 of 17
    PA
    Default Castrol power RS racing 4T 10W40 oil
    Has anyone used this oil and is it with in specs for the spyder 2010 RT SM5 998? Does anyone have any oil that seem to preform better then others in their spyder? Thanks for the help in advance. I have run the Moble 4T full synthetic in my other bikes with no issues but have not see it in 10W40.
    Active Member 11rtLTD's Avatar
    Mar 2017
    ICT
    Default Manual says
    Quote Originally Posted by chaz7771931 View Post
    Manual calls for a 5W 40 semi-synthetic (minimum) or synthetic motorcycle oil meeting the requirements for API service SL, SJ, SH or SG classification.
    I used
    Castrol 06113 Power1 5W-40 Synthetic 4T Motorcycle Oil - 1 Quart Bottle, (Pack of 6) https://www.amazon.com/dp/B008MISDII..._mlurLwt2ox2y7
    About 300 miles ago....so far so good.
    2011 RT limited , BajaRon plugs and custom wires Pearl white
    Houston
    In the SM5, Rotella T6 which is widely available works very well and meets specs. We do not use it in the SE6 due to an abundance of caution with customers bikes and the centrifugal clutch. We also use the T6 in all 1330 bikes.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    ...I have run the Moble 4T full synthetic in my other bikes with no issues but have not see it in 10W40.
    https://www.amazon.com/s/ref=nb_sb_s...d=VLYBC3GU7I0Z
    I've used it and always purchased at Advance Autoparts. Be sure it meets the API service spec for your Spyder as listed in owner's manual.
    Sep 2014
    USA
    I been running Amsoil 10W 40 metric with no issues..
    PA
    Thanks for the info
    Oct 2011
    Kalamazoo, Mi
    Default Castrol RS racing oil
    Might try Wally world for Valvoline 4T stroke full synthetic motorcycle oil 10W-40. When on sale you can get a six pack for ~ $6.00/quart. Have also used Amsoil metric 10W-40.
    2018 F3-T
    2018 F3-T , Pearl White
    Default great oil
    Quote Originally Posted by IGETAROUND View Post
    .... with the Valvoline .... it has the second Lowest Molybdenum in it .... Moly is known to cause issues with clutches.....Amsoil has the lowest ..... Mike
    PA
    that is what I have run in my other bike but have seen it in 5W20 around here but I'm sure I can order it online
    Thanks for all the advise
    Charles
    May 2009
    Connecticut
    I used the Castrol RS 4T in my 2012 RT with the 998 and It worked Great, JASO MA2 Rated! Important on the V Twin!!! And I use it in my 2015 F3 also!
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    Default I've used
    this oil since I got my bike at 2300 miles and now have 28,000 and have had no issues so far using Baja Ron's filters
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Default Gotta say...
    As long as you meet the spec's in the manual you are covered if you should have a oil related problem. There are many good oils that work great without meeting all the specs. I have used the semi synthetic XPS and have had no issues therefore see no reason to change as I have seen no significant difference in the others....jmo
    Jun 2017
    Albuquerque, NM
    FWIW, Shawn who post how to videos on you tube, etc, is a BRP mechanic. He says the XPS Semi Synthetic is 70% synthetic. Its made by Castrol to BRP'S specifications. I just used it at my 3000 mile service. I'll stick with it also.
    Houston
    There have been quite a few used oil analysis posted for the XPS showing it simply does not hold up for the BRP recommended change interval.
    Jan 2013
    Richmond va
    I used the Rotella T6 in our 2011 RTS SM5 for two years and was pleased with it. Then I switched to the Amsoil Metric. My oil use was halved. When we rode across country on a 7,000 mile journey I changed it before we left and again after we arrived home. I was amazed at the cleanliness of the Amsoil after 7,000 miles. I added one quart on that journey and it was still almost full before I changed it after we arrived home.
    Alan.
    PA
    Thanks to all for the responces
    Jun 2017
    Albuquerque, NM
    No problem, I would never let my oil go the distance BRP recommends. I usually change it at the beginning of each season. It usually has 5k or 6k on it.
