Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
  1. #26
    BUT I'm not sure I agree with using the "cruise control" for anything other than cruising.....long (mostly) straight road at constant speed.
    Putzing around with it in short term situations like a steep hill just seems to me like a distraction that you don't really need.
    To each his own, I guess.
    In a sense it is, "To each his own", but nevertheless it is a discussion that just might be worthwhile having. I guess we see the use of cruise control in different lights. As I said I use it as much as I can, even on city streets. The number one reason is that, as I see it, driving at a steady speed enhances the safety of everyone on the road. Whether it's in the car or on the Spyder I have trouble keeping a steady speed, especially if the road is up and down. What would be better is if everyone drove at the same steady speed but that of course that will never happen. If I'm staying at a steady speed at or just above the posted speed limit (usually about 4 - 5 above) I don't need to worry about getting a speeding ticket. On a hill the CC keeps me from slowing down and causing a driver behind me to get irritated, and then compensating by speeding up and further aggravating the guy behind me. For me, when I use CC I minimize the distraction of speed control and can devote more attention to all other aspects and distractions of driving. I see it as a safety feature, not a convenience feature. Most of the time the Spyder CC does a damn good job of keeping the bike at a steady speed, even downhill, sometimes by using a lower gear.
    As others have said, out on the open straight road I tend to be a 'creeper' in both directions, up and down. CC mitigates that problem. But there is the offsetting danger of using CC and that is complacency, especially on the open road. CC makes it a lot easier to sight see while driving, and that can lead to bad results if one does it too much and doesn't pay attention to the road ahead.
    Cruise control is a tool to aid in driving safely. Use it however it works best for you.
  2. #27
    Jul 2017
    sarasota, fl
    65 mph, and 6th gear comes to mind...
    But that's just me; you've got to ride your own ride!
    that's exactly the speed the OP mentioned and the speed with which easyrider has a problem
    65 sure works for me and is a good idea, not sure what he thinks is wrong with that
  3. #28
    Jun 2015
    Hampton Roads, VA
    Default Cruise in 5th here too...
    I use cruise as much as I can to maintain a desired speed, anywhere from the minimum that will set, about 28 mph, up to 85 on a 80 mph limit Interstate, in any gear from 2nd to 6th. In this case the hill was steep enough that the RT won't maintain 65 in 6th, hence my use of 5th. You can run a Spyder in 5th up to 80 for an extended time period, no problem!
    6th is fine for a long flat road to use cruise, but I like to keep the RPM in the 3500 - 4500 when using cruise. In hilly areas at 55-65MPH in 6th the engine gets a bit bogged for my taste. What's a few MPG
  4. #29
    Quote Originally Posted by stevencovert View Post
    You're probably saving more gas than you think in hilly country! Determining and controlling MPG is as successful as nailing Jello to the wall! I think it depends more on how hard the engine is working than what RPM it's turning at. Faster RPM at less strain I'm sure gives better mileage than lower RPM with more strain.
  5. #30
    Apr 2017
    North Central Florida
    Quote Originally Posted by ofdave View Post
    Please read ALL of the words in the posts that you are going to comment upon.
    He was at 65 MPH in FIFTH GEAR......with cruise engaged.
    I didn't necessarily have "a problem with that", but it is unusual and I wondered why.
    Do you have a problem with THAT ??
  6. #31
    Cruise control usage: Answers will be all over the place.
    Me? I don't use it in town, or in heavy traffic. One mistake and you get bit.
    I always use it on the highway--mostly to maintain speed at a couple miles per hour over posted. That puts me in the "flow" most of the time. Also use it when on slower deserted roads where I want to maintain a certain speed. I am also a "creeper" and cruise cleans that up for me.
    I always drive with the "best" gear. For me that keeps my engine in the "happy" spot. 5500 on our 998 and 3500 on our 1330. Cruise will work in any gear as long as your speed is above 28 or so mph.
    You? Do what works for you.
    Apr 2017
    Opinions are like.....well you know !!
    Thinking that some given RPM is "best" when cruising down the highway is a bit short sighted in my opinion.
    Especially your 5500 figure for the twin.
    Except for somehow making you feel good, I see nothing that qualifies that for "best" status.
    NOW.....if you are in traffic that is speeding up and slowing down or you otherwise want to be able to accelerate quickly, then I've got no problem with keeping the RPMs up to where your available HP is more. But with the cruise control set.......NO reason (unless maybe the terrain is really hilly).
  8. #33
    The sweet spot will vary from to . One needs to find theirs. Feel and sound are my two. At the 5500 rpms that is where the 998 comes "alive." This allows you to get up and go if needed. The 1330 is a bit different. For me, 3500 happens when is cruising down the highway at 65 in 6th. It increases from there with speed. The 1330 has great low end torque, you can just twist and go from pretty much 2500 and up if needed.
    As I mentioned earlier--opinions will vary. Just letting others know what works for ME.
    Apr 2017
    Which I acknowledged in my last post.
    But I also said that needing to "get up and go" is highly unlikely when actually cruising down the highway.
    There is absolutely, positively NO ADVANTAGE to running an engine faster than is necessary to maintain a cruising speed.
    AND......if you are doing that by running in a lower gear, then you are putting unnecessary wear and strain on the engine.
    But if it makes you happy......
  10. #35
    Jul 2017
    sarasota, fl
    No problem with THAT
    a problem with your attitude though
    I see from many of your posts you like to argue and are confrontational.
    I did not join this forum to deal with that crap so I will just ignore what you have to say from now on.
    Could be the OP meant 6th but typed 5th.
  11. #36
    Apr 2017
    Pot.....kettle......black.
    BYE.
  12. #37
    Nope! I was in 5th! Hill is too steep to hold speed in 6th.
  13. #38
    Well, thanks for telling me how to drive my . I guess I have been doing it wrong since 2008 and those 135,000 miles have meant nothing. Never mind that I have never had a major mechanical problem over 5 assorted. Never mind that the Buds report indicated that our current operations (2015 and two 's) had been driven in the proper gear ranges most of the time.
    One point possibly missed--over 60 mph gets 5th gear on the 998 and 6th gear on the 1330. If we are driving less than highway speed--then the appropriate gear for the speed is used.
    Another point possibly missed is that the Rotax (998) LIKES high rpm's.
    We have had the attitude discussion behind the scenes--and I will leave it at that.
    Apr 2017
    There is no "attitude" here.
    I'm trying to have a useful, adult discussion without looking to pick apart the motivations or style of the other person in the "discussion".
    Maybe that isn't possible.
    And yes, that point was missed because it wasn't included before.
    Just because a given engine NEEDS to run at 5500 RPM at 70 MPH in top gear does NOT mean that it is somehow good for it to run up to 5500 in every gear before shifting. And a really lot of engines develop more impressive HP at higher RPMs.......but that doesn't mean that the engine "likes" to run faster than it needs to. No doubt the RIDER likes that, but the engine.......not so much.
    There really is nothing wrong with running YOUR engine at whatever speed you like, within the design range.
    But to claim that running it at a higher RPM than is needed at a given speed is somehow "good" for it......or that it "likes" to run faster......just doesn't stand up to rational analysis.
    I think we've about beat this to death. Truce ??
  15. #40
    The "sweet spot" on my 998 is 5500 for shifting and 3500 on the 1330. No clunks--smooth as butter to the next gear. The Red line for the 998 is 9000 rpms. I have never been over 7000 that I know of on the 998. Truce? Absolutely.
    Mar 2017
    Star, Idaho
    IdahoMtnSpyder, I do that hill all the time, it is too steep for 6th gear. I set my CC at 55 and speed up with throttle when I can, I'm not experienced enough to go 65 yet (curvy road). The picture on my signature is on Highway 55 just south of Banks, I go to my brother in laws cabin in Crouch all the time. I used to be intimidated by that hill but now I look forward to it. Hope to see you some time.
  17. #42
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    Default rpms
    So he likes to wast fuel... that's his choice!
    Personally: I'm in sixth gear at 39 mph on a flat stretch of road.
    I use rpms and grade to determine what gear to run in, not speed. I'm OK with anything above 2500 on the flat, but on any grade I want to be above 3000, usually 3500. For me sixth is a long distance cruising gear for flat freeways.
