Results 1 to 16 of 16
    Aug 2017
    Coon Rapids, MN
    Default How many battery connections is too many?
    I see a lot of accessories that are connected directly to the battery terminals. How many is too many? Are there any simple connectors that can be added to accommodate multiple post connections? Any insight on this subject appreciated. Thanks!
    Scott
    Default MULTIPLE CONNECTORS
    Quote Originally Posted by Sbdraz View Post
    Scott
    The most I would put on a Standard terminal bolt is ..2... if you get a longer bolt you can have more .... but I wouldn't ... Add a cheap fuse block .... go to Bangood.com ....I bought one for $6.00 .... It's fused and doesn't need to be expensive to do the job you are using it for .... Some folks here spend $ 50.00 or more for a fuse block .... maybe theirs makes coffee too ...... Mike
    Default Well....
    with both gentlemen above...many times the more you put on the battery the more issues you have with loose and faulty connections. That results in no starting up and many warnings etc...
    ​2012 RS sm5
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    Check out FuzeBlocks FZ1. It is pricey (and it does not make coffee) but it gives you the option of keyed or constant power for your accessories simply by where you place the fuse. I have one on my M109R and it works great.
    http://www.fuzeblocks.com/index.php?pid=10
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    You may want to try this offering from Lamonster, two sets of terminals, just for you.
    http://cdn3.bigcommerce.com/s-1dz5qu...0.1280.jpg?c=2
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Scott,
    Re: I see a lot of accessories that are connected directly to the battery terminals. How many is too many? Are there any simple connectors that can be added to accommodate multiple post connections? Any insight on this subject appreciated. Thanks!
    My son-on-law who is both a motorcycle guy and an electrical engineer, bought one of these:
    https://easternbeaver.com/Main/Wirin...8.html#pc8only
    I will soon be adding some more lites to my Spyder and I am thinking about getting one of these; it seems like it will make things much simpler.
    Jerry Baumchen
    PS) With the PC-8 you can have a Battery Tender on one of the unswitched circuits.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Active Member Bandera's Avatar
    Bandera, Tx
    Take a look at "Value-Accessories" on the home page. They have some 4 & 6 terminal power blocks.
    W5MWI
    USN Vet - RM1
    Member: VFW & American Legion
    2020 Spyder RT-L - Jupiter Metallic Blue Chrome
    Active Member sidecarrick's Avatar
    May 2015
    Otisville, N.Y.
    Quote Originally Posted by Navydad View Post
    There are many accessory terminal blocks available for motorcycles. You wire these to your battery and then wire your accessories to the terminal block. This will keep battery connections to a minimum. Lots of these terminals are already equipped with fuses so you don't have to deal with that issue. I haven't checked any of the vendors on this site, but I'm willing to bet at least one of them may have what you need.
    Do that!
    Sep 2016
    dilworth,minnesota
    Default hooking directly to the battery
    had only two things hooked directly to the battery a hookup for heated gear and the show chrome wiring harness for my trailer these hookups were questioned when a dess code occurred and were unhooked still haven't determined I the connections to the battery were the reason for the codes but must be concerned with it when hooking anything to the battery directly.
    Jul 2014
    Nowhere
    Quote Originally Posted by JerryB View Post
    Hi Scott,
    Jerry Baumchen
    Jim (Eastern Beaver) makes good kit and ships quickly. You would never know that the items came from Japan if you didn't look at the mailing address. He's a BMW owner and has been in the business for a long time (15+ years that I am aware of). I've purchased his kits on 4 occasions and have been pleased with the quality each time.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    If you use ring connectors for the battery that allow wire to be clamped on/in them, you can put two or three wires in one connector.
    Gives you one hook up to the battery and two or three wires to power stuff.
    Remember to use an appropriate size fuse on each circuit you add.
    2017 F3, SM6-basic black, plain and simple
    Dec 2015
    Oakley Utah
    Good tip, thanks.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Buckeye Bleau View Post
    You may want to try this offering from Lamonster, two sets of terminals, just for you. http://cdn3.bigcommerce.com/s-1dz5qu...0.1280.jpg?c=2 Joe
    An AGM battery with two sets of terminals. Great idea.
    2014 RTL Platinum
    May 2014
    Beaverton, Oregon
    Hi Pete,
    Re: Good tip, thanks.
    Here's another one:
    http://easternbeaver.com/Main/Elec__...seholders.html
    I recommend that you buy the 30 Amp fuseholder to go with it:
    Cooper-Bussman 30A Fuseholder for ATM Type Mini Blade Fuses
    It's only $3.95.
    I am going to buy both the PC-8, the 30 amp fuseholder and his Velcro to mount the PC-8:
    http://easternbeaver.com/Main/Wiring...PC-8/pc-8.html
    PC-8 Mounting Accessories: You can come up with your own mounting materials and methods but here are some high quality mounting bits to help you mount the PC-8 to your bike.
    Dual Locks Strips - Two pairs of mating 3” (8 cm) Dual Lock strips.
    Only $2.95 more,
    Jerry Baumchen
    PS) I bought some 12 guage stranded wire in red ( 8 ft ) & in black ( 4 ft ) up at Home Depot this morning; you'll need some of this also, to go from the battery terminals to the fuseholder & then to the PC-8..
    2008 GS SE-5
    Default DESS - BS
    Quote Originally Posted by rustynail51 View Post
    you are getting stroked by that dealer ...... accessary connections have NEVER been a cause for the DESS warning ..... your modem is failing and they MUST re-place it under Warranty .... because at some point it will Fail completely and nothing you can do will start your Spyder ...... Mike
    Sep 2016
    dilworth,minnesota
    thanks Mike
