Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: Relays
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Default Relays
    Hi folks,
    I am going to be doing some new wiring on my Spyder and have been looking for Normally Closed Relays.
    I usually buy my relays from Eastern Beaver because he sells good stuff:
    https://www.easternbeaver.com/Main/main.html
    However, he does not carry a Normally Closed Relay.
    After a lot of time on the 'net, lots of emails, too many phone calls, I found this:
    https://www.alliedelec.com/schneider...d-12/70185037/
    And what is even better is that it can control two seperate lites seperately.
    Now, I have not yet gotten this little guy here to actually try/use; I'll try to keep you posted on how it works.
    Just some info for those nutty DIY'ers like me,
    Jerry Baumchen
    PS) Here is a sketch of what I am trying to do:
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Gonna watch this one. Above my pay grade.
    Default I'm with him...
    not totally sure what the plan is....If they are that hard to find must not be used that much.... like eastenbeaver.....
    ​2012 RS sm5
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    Default Relays
    Unless I am not reading you right, you are looking for normally closed relays.
    Why normally closed? Most general market relays are of the open contact variety
    of a 30 amp rating and closed when you apply power to the coil of the relay. This in
    turn applies power to one or 2 output terminals to switch something on. Normally
    closed relays would require a constant power source to keep the relay open and break
    the flow of power. Please keep us posted as to what you have going on. My curious Pea
    brain would like to know.
    Thanks in advance
    Dray
    May 2014
    Beaverton, Oregon
    Hi Dray,
    Re: you are looking for normally closed relays. Why normally closed?
    Gene De Laney ( Chupaca ) on here added these lites to his Spyder, they mount onto the sides of his frunk:
    Gene controls his with an On/Off switch mounted on his handlebars.
    I am wanting to add one driving lite to each side of my Spyder at the front as Gene has done.
    However, I do not want to have to use a On/Off switch; too easy IMO to forget resulting in a dead battery
    1. Look at the sketch in my OP - I will come from the battery ( power from the battery, not from anything else that might upset the CanBus on the Spyder ) to an in-line 3 amp fuse ( protection for the lites ), then to a Normally Open Relay - This N O relay will be tripped by somewhere on my Spyder by power that only comes on with the key; probably grab this tripping power from the headlite wiring. This keeps the driving lites on when I am out riding around yet turn them off when I shut down the Spyder; which is what I want.
    2. Then the power will go from the N O relay to the Normally Closed Relay ( I found one that is a single relay that can control two circuits individually ). Then I will bring two tripping wires from my existing turn signal circuits; these will then open either side of the N C relay, thereby interrupting the power to the driving lites and making them into additional turn signals.
    Does that make sense to you?
    If not, let me know & I'll give it another try.
    Jerry Baumchen
    PS) The human species can be very inventive. Plus, I like thinking outside of the box.
    2008 GS SE-5
    Jun 2015
    Hampton Roads, VA
    Default Ahhh Brilliant!
    Quote Originally Posted by JerryB View Post
    Hi Dray,
    Jerry Baumchen
    So one light is on 100%, other blinks; or one light that also blinks. Great idea! Yes, tapping the blinker & headlight wires to drive the coils of a relay is super safe - I chose the relay version of the trailer wiring kit for the same reason.
    May 2014
    Beaverton, Oregon
    Hi Alaska,
    Re: Above my pay grade.
    It was for me also before I learned enough to be dangerous.
    I'll take a go at explaining relays to you. If anyone here thinks any of this is wrong, jump in as I am no expert.
    About 20 yrs ago I put in a new garage door opener. The lite that was built-in on the garage door opener was a 60 W bulb & it only would lite up ( somewhat ) the front of the garage, the area from the motor/lite on the opener towards to garage door. The rest of the garage was quite dark. This 60 W lite bulb stays on for about 3 minutes whenever the garage door opens or closes.
    I dug into the tech info ( I'm a ret'd Mech Engr ) for the garage door opener & started reading. It said to never replace the 60 W bulb with a bigger bulb because the circuit could not handle the additional load.
    So I bought a relay & located it up above the sheetrock in my garage.
    I brought 110 V power in from somewhere in the house; a constant power source.
    I then added two large flood lites to the area of my garage that was not lit by the little 60 W bulb.
    So now, I have 110 V power coming into my relay & going out to the two floodlites, when the relay is tripped & only when it is tripped.
    Then I tapped into the 60 W lite bulb circuit ( a fairly simple soldering job ) and ran this wire to my relay; this is the tripping wire. It sends a very low voltage signal to the relay.
    So now when I pull into my garage, the 60 W bulb lites up & my two floodlites also lite up; all for the 3 minutes that the garage door circuit tells them to.
    Does this help explain what a relay does?
    Jerry Baumchen
    PS) What I call the 'tripping' wire some people will call a 'control' wire; different strokes for different folks.
    2008 GS SE-5
    May 2014
    Beaverton, Oregon
    Hi Steve,
    Re: So one light is on 100%, other blinks; or one light that also blinks.
    No. Both driving lites are on when the key switch turns them on & they stay on while just driving down the road.
    Then when either turn signal is turned on, the Normally Closed Relay for that lite becomes open, turning that driving lite off. It ( hopefully ) will blink On - Off, but just the opposite of the turn signals.
    Re: Great idea!
    Well, I like to think so. We'll just have to see how it works when I get everything installed; just waiting on the N C relay to arrive.
    Jerry Baumchen
    2008 GS SE-5
    May 2014
    Beaverton, Oregon
    Hi Gene,
    Re: If they are that hard to find must not be used that much....
    Actually, a single Normally Closed Relay is almost always a Normally Open Relay also. It just performs either duty depending upon how you connect the various wires to it.
    I found a single relay that can control two seperate circuits, that was the hard item to find.
    I could have bought two relays, one for each driving lite but that would be more bulk. I plan to put this Normally Closed Relay right behind my instrument panel, so I did the extra work to find a single unit that ( hopefully ) will control both driving lites.
    That's my story and I'm sticking to it,
    Jerry Baumchen
    2008 GS SE-5
    Oct 2015
    Lynden, WA
    Default Transistor Switch
    Hi Dray,
    Jerry Baumchen
    Jerry,
    I cobbled up a transistor circuit that does what you are attempting with relays.
    I use it for running my saddle bag LED lights as running lights, brake lights and turn signals.
    The LEDs are on all the time except when interrupted by the turn signal power.
    Then the LEDs flash opposite of the turn signals.
    Less than $5 in parts and very little space. Best of all it doesn't mess with the Canbus.
    PM me and I will send you a copy of my circuit diagram. No I'm not an electrical designer, just a DIYer.
    My circuit values are probably overkill but it works.
    Cheers, David C.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    May 2014
    Beaverton, Oregon
    Hi David,
    Re: Less than $5 in parts and very little space.
    1. Building a circuit board is WAAAAYYYYYY over my pay grade.
    2. It turns out that the relay supplier has taken mercy on me & are providing it for free.
    Sometimes it helps to be a little charming when talking to women on the phone.
    Jerry Baumchen
    PS) Could you post up some info on how you designed it? That might help the other nutty DIY'ers on here.
    PPS) Offers like this is why I really like this website.
    2008 GS SE-5
    May 2014
    Beaverton, Oregon
    Hi Steve,
    I just realized what you were referring to with this.
    As shown in the photo, Gene has two lites on each side of his frunk.
    I am installing just one lite on each side of my frunk. Ergo, both lites on all the time with one getting interupted when the specific turn signal is activated.
    Jerry Baumchen
    2008 GS SE-5
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    You guys are making this way to complex. You can get those cheap 12vDC relays that are single pole double throw: http://www.ebay.com/itm/5-sets-40A-W....c100505.m3226
    I used these to make my fender LEDS flash as turn signals, here is the schematic:
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    May 2014
    Beaverton, Oregon
    Hi Bill,
    Re: You can get . . .
    As I mentioned in Post #9:
    I know that I could easily buy two relays but I found a single relay to control both lites. That was the gist of my OP.
    Jerry Baumchen
    2008 GS SE-5
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Jerry, I like your idea! Pretty crafty, mister!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Oct 2015
    LeRaysville Pa.
    Default You want relays
    I get most of my relays for my work applications through Grainger. They have them in any voltage and configuration you would want.
    May 2014
    Beaverton, Oregon
    Hi Bob,
    Re: Pretty crafty, mister!
    Let's not get ahead of ourselves. The mfr says it will do what I am wanting. When I get the relay & get it wired in, then I'll know if this idea is worth anything.
    I'll try to keep this thread updated as things go along,
    Jerry Baumchen
    PS) From Post #5: I like thinking outside of the box.
    Trying new things to see if they will work or not is what makes life interesting.
    2008 GS SE-5
    May 2014
    Beaverton, Oregon
    Hi Cabinkids,
    Re: I get most of my relays for my work applications through Grainger. They have them in any voltage and configuration you would want.
    Many, many years ago, a good friend worked at the local Grainger outlet. That is how I began dealing with them.
    I have bought a 'fair' amount of stuff from Grainger over the years.
    I could not find the relay that I wanted at Grainger. They might have one like it but I could not find it & they could not put me onto one.
    IMO Grainger is a very good company; no complaints with anything that I have ever bought from them.
    Jerry Baumchen
    2008 GS SE-5
    Jun 2015
    Hampton Roads, VA
    Default Now that I get what you want - this is it!
    Quote Originally Posted by pitzerwm View Post
    Almost. This circuit will flash the LED when the turn signal is ON. I think he wants to have a marker light that is ON all the time, that flashes during the turn signal. Seems like moving the "hot to fender lights" on the right side to the N.C. position fixes it. The light is ON all the time, then turns OFF when the turn signal is active. It will just blink out of sync - which looks cool! At least I THINK that's what he wants . It's what I would do - more lights the merrier!
    Steve
    May 2014
    Beaverton, Oregon
    Hi Steve,
    Re: The light is ON all the time, then turns OFF when the turn signal is active. It will just blink out of sync - which looks cool! At least I THINK that's what he wants . It's what I would do
    Yes, that is what I am planning doing.
    Re: This circuit will flash the LED when the turn signal is ON.
    I read his schematic the same way.
    Jerry Baumchen
    2008 GS SE-5
    Nov 2014
    TriCities, WA
    Quote Originally Posted by stevencovert View Post
    Steve
    Look again, when the turn signal is not on, you have your fender lights on, (the hot lead goes thru the NC contact, from battery to fender) when the turn signal is activated, it is opposite/out of sync, but flashes the fender lights. You need one for each side.
    Oct 2015
    Lynden, WA
    Default Transistor Circuit for Switching and Flashing Lights
    I built this circuit for my LED Saddle bag lights.Should be easy to adapt to front driving or marker lights.
    Use any keyed power wire as a source for your lights. Tie into the turn signal wires for controlling the flashers.
    Very small. Just a transistor and a couple of resistors and diodes. Nothing critical or fancy.
    Tail light, Brake light and Turn signal controller.
    LED tail lights are on with the key. LEDs also act as Brake lights. Brake light over rides the tail lights. LED tail lights blink in opposition to the turn signals. Turn signals continue to blink when brake light is applied.
    I made all my connections at my trailer wiring harness.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Jul 2011
    Mitchell, Ontario, Canada
    Interesting project JerryB.
    If it was me. I would just get 3 SPDT relays and then just use the NC or NO terminal depending on what I wanted the relay to do. But it is very good to see things done a different way and with different components.
    For a trigger voltage to turn the driving lights on. I would tend to go for a circuit controlled by the load shedding relay. That way the the lights don't come on until the engine starts. On a 08 GS an easy circuit to get to would be the front trunk accessory plug wire. I have not double checked but think it is ECM switched. Just a personal preference, does not matter either way.
    When you get it done please post a video of how it works.
    2018 F3 LIMITED
    May 2014
    Beaverton, Oregon
    Hi Billy,
    Re: Interesting project JerryB.
    Thanks; as mentioned, I sort of like thinking out of the box.
    Re: For a trigger voltage to turn the driving lights on. I would tend to go for a circuit controlled by the load shedding relay. That way the the lights don't come on until the engine starts. On a 08 GS an easy circuit to get to would be the front trunk accessory plug wire. I have not double checked but think it is ECM switched. Just a personal preference, does not matter either way.
    I'm not 'electrical' enough to know what 'load shedding' means but I do want to have the lites so that they come on well after the Spyder is started up, not just when the key is turned. I have not yet checked to see if the headlites work this way or not.
    Re: On a 08 GS an easy circuit to get to would be the front trunk accessory plug wire.
    Any thoughts on just where this wiring is located? I am planning on mounting the lites to the sides of the frunk so I could bring them up to behind the instrument panel together.
    Re: When you get it done please post a video of how it works.
    I will try to do so; I'll probably have my daughter help me.
    And thanks for your comments,
    Jerry Baumchen
    PS) This has become an interesting thread. I really just started it to tell people about the unusual relay that I found.
    2008 GS SE-5
    Jul 2011
    The front trunk accessory circuit is connected to the trunk power plug if you have that option. If you do not have that option the wires and rubber boot are zip tied to the frame on the left side behind the trunk. I checked the wiring diagram and it is controlled by the ECM so I would assume that it will turn on when the engine gets to idle speed for the first time after engine start.
    If you do not have the optional power plug and do not plan to install it. I would use that circuit as your power source. It is used for nothing else. That would save you one relay and fuse in your circuit. It is protected by a 3 amp fuse in position 3 in your fuse box. Will guess that the fuse maybe already installed. I think 3 amp would be good enough for what your doing. But if not the wires are heavy enough to go to 5 amp fuse.
    2018 F3 LIMITED
