Thanks Thanks:  9
Likes Likes:  14
Results 1 to 20 of 20
Thread: ROAD GATOR
    Very Active Member jtpollock's Avatar
    Feb 2013
    Castle Rock, Co.
    Default ROAD GATOR
    WOW it's been a while ... Getting ready for retirement work has really keep me going taking all my time. Anyway This morning rolling down the Highway as I do every morning. Keeping an eye on all the nuts on the highway a double trailer semi pulled in front of me at a slower rate of speed than I was doing so I signaled and moved over only to find a ROAD GATOR (Large Truck Tire) Stretched across my lane it ripped the noise 3/4 of the way off my RS. It took the better part of a mile before I could get enough shoulder to stop. Thest new HOV lanes tale away the shoulder to add more yahoos to the road. So I will be looking for parts to fix my 2012 RS and I need to keep it on the road cause it's my only means of transportation to and from work.... 12 more working days jtpollock.
    2012 RS-S SE5 NUTRON Green Metallic/ Satin Black
    MADCO Cam-LOCK
    TricLED fender Lights
    23" tour windshield
    trailertec hitch
    harbor freight trailer
    smothspyder belt tensioner
    Sturgis Saddle Bags
    passenger back rest
    rear seat mod by bitchn stichn
    4.5" bar riser by easy riser
    HMF slip-on exhaust
    JT's air filter
    IPS Key cover
    Aux Fuse Block
    Shark Audio SHKC 6800 4 Speakers
    Rear passenger peg extentions
    Very Active Member quasi's Avatar
    Oct 2015
    morgantown west virginia
    WOW, glad it wasn't any worse than that! lucky. be sure and take a look at the tie rods when you get the nose off of it. enjoy your retirement!
    man can't live on air alone
    2012 RT-S SM5
    United States Navy Veteran 28feb74/28aug81+ 2yrs active reserves
    RM2 2318/Communications Systems Tech Control Operator
    Active Member classicvw's Avatar
    Aug 2017
    New Jersey
    Glad you're OK. Don't take any chances and maybe rent a car while you look over the Spyder well.
    The rims are also prone to damage from relatively minor impacts.
    Very Active Member Saluda's Avatar
    Aug 2008
    MA & NH
    Glad you are OK, good luck on the retirement.
    ​Never stop questioning
    May 2013
    Apex, N.C.
    Glad that you didn't get hurt. This is one of those times that you probably wouldn't have faired so well if you had been on 2 wheels. Hope you get it fixed with minimal expense, and good luck with your retirement.
    Very Active Member PrairieSpyder's Avatar
    Sep 2012
    Junction City, KS, USA
    Wow!! That could have been a lot worse. Glad you're OK and on your impending retirement!
    PrairieSpyder (Patti)
    2016 F3T, Intense Red Pearl. Purchased 4/25/16, 0 miles.
    2014 Spyder RTS SE6, Circuit Yellow. Purchased 4/28/14, 0 miles. Ultimate seat, vented windshield, bump skid, Baja Ron anti-sway bar w/links. About 25k miles when traded in.
    2011 Spyder RTS SE5, viper red. Purchased 9/26/2012, mileage 6,172. Traded 4/28/14, 11,100 miles
    VERMONT
    Default JUST A POSSIBILITY
    Quote Originally Posted by jtpollock View Post
    If you can get the FRUNK off ... the Spyder can SAFELY be driven without the FRUNK until you can get it fixed or re-placed ...... I have driven mine this for extended periods of time ...even in the Rain ....... the only thing you will notice is a flashing orange where the mileage box is and an engine symbol in the right corner .... also your Temp will read 68 degree's ..... good luck ... Mike
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Road gaters are one of my biggest fears. I live close to an interstate and have to watch for those critters all the time. Glad you made it through the experience.
    2011 RTS
    1998 Honda Valkyrie
    US Navy Veteran
    CNC Machine Service Technician
    Member: Rolling Thunder
    Vice Commander: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Feb 2013
    Castle Rock, Co.
    Mike thanks for the info I just took a look and its JUST!!! the BUMPER Cover Rt lower Deflector Skid Plate the suspension looks to be OK Wheels and tires are good It may not be as bad as it could have been Thank to all with well wishes.
    MADCO Cam-LOCK
    23" tour windshield
    trailertec hitch
    Sturgis Saddle Bags
    passenger back rest
    HMF slip-on exhaust
    JT's air filter
    IPS Key cover
    Aux Fuse Block
    Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default It's good that you fared so well...
    ... in this road gator incident. It sounds like there are two pieces of good news... 1) You are fine and came through with no serious injuries and 2) there is less damage than could have happened. Congratulations on your retirement! Finish well and I know you will enjoy you retirement years... we sure do! There is a period of adjustment that is pretty common. When I first retired, I got up (later than normal - didn't have to roll out at 5:30), had my coffee, finished last night's paper, and then said, "Now what do I do?" Well, I have been retired a little over three years and now I say, "How did I ever have time to work?" We are doing what we want to do and our days of full of all kinds of activities. Congratulations.
    Jim
    HI YO SILVER!!
    Ryde, eat, sleep.... repeat
    2010 RT SM5
    Added 12 volt outlet on dash
    Kuryakan Widow Pegs
    BRP trailer hitch
    While at Spyderfest 2017, added
    BajaRon Swaybar
    Spyderpops Lighted bumpskid
    TricLED Wide View mirrors
    Feb 2013
    Castle Rock, Co.
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Jim,
    Thanks I am looking forward to not driving 36 miles one way every morning that 36 miles would be better in the mountains. I am retiring after 39 years in the same office doing the same job and will have spent my whole career in a building that will be torn down one year after I leave. Hard to believe a Building will not last for more than 40 years. jtpollock
    MADCO Cam-LOCK
    23" tour windshield
    trailertec hitch
    Sturgis Saddle Bags
    passenger back rest
    HMF slip-on exhaust
    JT's air filter
    IPS Key cover
    Aux Fuse Block
    VERMONT
    Default BUSY RETIREMENT
    Jim
    ..............enjoy .....Mike
    Active Member HIspyder's Avatar
    Sep 2014
    Kauai (The Garden Isle), Hawaii - USA
    Road Gators are not fun!
    I had the pleasure of running over one at night on the way up to Valcourt and managed to get air-born. A real white knuckle experience but managed to keep the F3 under control.
    Glad to hear you're okay and happy retirement. 6 years to go and counting for me.
    Just another crappy day in Paradise....Aloha!
    Consumer Advocate akspyderman's Avatar
    Chugiak, Alaska
    Glad to hear you are all right. Happy retirement--you are going to like it.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 9 years, 139,000 miles, 5 Spyder miles per post.
    Feb 2013
    Castle Rock, Co.
    Thanks all... this is what I like about this site everybody. As far as retirement after 39 years at this job 7 years in my own buisness and 4 years in the USAF I am looking forward to some R&R, putting my Spyder back together and some long rides in the Mountains of Colorado. Thanks again to all. jtpollock
    MADCO Cam-LOCK
    23" tour windshield
    trailertec hitch
    Sturgis Saddle Bags
    passenger back rest
    HMF slip-on exhaust
    JT's air filter
    IPS Key cover
    Aux Fuse Block
    Default Yikes...!!
    Congrats on the retirement.. Always start with the good...Bummer about the road gator.. hope you can get all the parts quickly but as Mike stated you can manage with out the frunk till then. Glad your good and handled it so well...
    ​2012 RS sm5
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    Look on the bright side: Retirement is coming along at a very opportune time!
    And the damage isn't as bad as it could have been!
    on no more punching timeclocks!
    2010 RT A&C ................................. 2014 RT Limited.
    (Both are gone, but not forgotten!)
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    God was your copilot. you could have been badly hurt too.enjoy retirement.--irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], doc's
    vibration damper, rock guard, and side case stiffener kit,
    7 jurock w/shield. brp comfort seat. led h/ls, fomozas and
    altimax, magic mirror mts, and tricled wide mirrors.
    [joyce & irvin toms]
    Feb 2013
    Castle Rock, Co.
    Default Road Gator
    O.K. I took a close look last night the frunk was not damaged. The Road Gator was very hungry it ate my Smooth Spyder, the Bumper cover ( BRP Parts Name) the Skid Plat, the lower Deflector and the front Panel (the one that holds the fog Lights on the RS) then I notices how close it came to getting me as half of my foot rest is missing... that was close. jtpollock
    MADCO Cam-LOCK
    23" tour windshield
    trailertec hitch
    Sturgis Saddle Bags
    passenger back rest
    HMF slip-on exhaust
    JT's air filter
    IPS Key cover
    Aux Fuse Block
    VERMONT
    Default GATOR
    ..... those things weigh quite a bit ...... glad YOU weren't hurt ...... Mike
