Results 1 to 11 of 11
    Active Member chaz7771931's Avatar
    PA
    Default radiator additive for 2010 RT SM5
    With the 998 running high RPM is anyone using a radiator additive to help keep the motor cooler? My RT is gunning from the middle to almost red hot mark when I'm in traffic or below around 40 MPH.
    Thanks for any info
    Oct 2014
    Fort Mill, SC
    I have never used an additive. Your temp sounds normal. In the winter mine doesn't get up to half way and in the summer it gets close to the red in stop and go traffic. Just make sure your fan is cycling.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    PA
    Quote Originally Posted by Grandpot View Post
    Ok thanks for the info
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I have a 2010 RT SM5...
    ...and my temp only goes about 3/4 way up when sitting in traffic. Never been close to red... as suggested, be sure to check your fan to be sure it's cycling. After a long ryde and shutting off the Spyder my fan runs for a short time... does yours? Also check the fluid levels.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited Pearl White/Dark
    LaMonster drink holder with X-Grip
    LaMonster Belt Dampener
    Lamonster USB cable with extension
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    PA
    Quote Originally Posted by BigGuy66 View Post
    Jim
    Everything checks out ok, all the fluids on the bike are scheduled to be changed at the 20K service so since it is getting change was thinking about getting the additive while they are doing the srevice anyway.
    Very Active Member jwulf74's Avatar
    Jul 2013
    Piedmont, SD (Black Hills)
    I pulled the air box and related plumbing out and put in the one from JT. I also did the Cat delete... temp needle rarely goes over 1/2 now...
    2017 Can Am Commander Limited
    2012 Cadillac CTS-V Black Diamond
    2020 F3 Limited Magma Red (miss the 2011 Viper red)
    2010 RT622 - Black
    I've used Engine Ice in liquid-cooled ATVs. That's about as extreme as the conditions can get: low-range riding in the middle of Summer, with a mud-clogged radiator!
    My Quads always ran cool!
    The engine will heat up in high temperatures and idle (for long times) situations. We got stuck in a traffic accident on Maui, HI and after about a half hour, the engine went into limp mode and stopped. A half hour later, it restarted and drove just fine.
    The radiator fan should be kicking in a bit before the limp mode thing happens though.
    My usual in a traffic parking lot is just to shut the engine off when not moving. Never had any problems with that method.
    Jun 2015
    Hampton Roads, VA
    Default Additive
    I used: http://www.autozone.com/antifreeze-r...ool/302501_0_0
    in my big Yamaha. Worked well. Somehow this makes the water "wetter" letting it get into all the spaces. Never thought about using it on my RTS, but I have the 1330 and it never runs close to hot (4 bars) stopped in traffic with the fans cycling. With my 2013 ST it did run hot, I didn't think to try this stuff at the time.
    Houston
    An additive is not needed or desired. If your temp gage is getting up to the red zone you have a cooling system problem that needs to be fixed. The RT, even the 998s have a more than sufficient cooling system. They show never overheat or go into limp mode even stuck in traffic.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    PA
    Thanks for the info from everyone.
