Results 1 to 21 of 21
    Aug 2016
    Calverton N.Y.
    Default Fender amber leds
    Looking for some help with my new fender amber LEDS.
    I have a 2013 RT. I am in the middle of changing out the amber deflectors with LEDS on the front fenders.
    I bought the LEDS from big bike. The wiring is hooked up as instructed. The blinkers are working fine but I cant seem to get the running lights on them to work.
    All the connection are fine.
    Any ideas?
    Thank you.
    Robert
    Jun 2015
    Hampton Roads, VA
    Default Do they have the blinker function?
    I added this kit to my 2013 ST-LTD, they did not blink, just solid on marker lights. If there are only two wires going to the LED (with no little circuit board) then they are marker lights, and need to get connected to a marker light wire to be ON all the time. How about a link to the specific LED kit?
    Steve
    Aug 2016
    Calverton N.Y.
    Quote Originally Posted by stevencovert View Post
    Steve
    There are 3 wires, RED, BLUE and Black, going to the LEDS. ! is going to the mirror blinker the others are going to the head light. The ones going to the head lights should be the running lights.
    I tried looking for any videos could not find any.
    Thanks
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    I only use mine as running lights, hook to the two wires in the fender. Not sure why you are running the wires to the headlights. Must be a different connection. Check your connection, maybe one is not making contact!
    If you add that many more blinkers: you're also going to be adding resistors to the system. You WILL start experiencing hyperflash!
    Aug 2016
    Calverton N.Y.
    How can I correct hyperflash from happening?
    Would you happen to know how to solve the problem with the running lights not working?
    Thanks
    Aug 2016
    Calverton N.Y.
    Quote Originally Posted by Larry rt View Post
    The instructions said to run the BLUE and Black wires to the headlight. I guess to have them work as running lights. Yes check all connections.
    Thanks
    Jun 2010
    Las Vegas
    The connection should be to the fender tip light not the Headlights.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2010
    Knob Noster, MO.
    Quote Originally Posted by Rawspyder View Post
    Thanks
    While I don't know about your set, but the wires should be as follows. Positive and ground to fender light, and another to the blinker.
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    May 2010
    Knob Noster, MO.
    Quote Originally Posted by SpyderAnn01 View Post
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    Jun 2015
    Hampton Roads, VA
    Default Test?
    Thanks
    I assume RED is marker. Just to test, add BLUE to red connection, get brighter? (could be other way around for colors). Just want to verify you can get two levels out of LEDs.
    Steve
    Aug 2016
    Calverton N.Y.
    I did think about making that connection with the blue wire today. Going to try it see how it works.
    Thanks
    Aug 2016
    Calverton N.Y.
    Steve
    Will try that.
    Thanks
    Apr 2013
    Wisconsin
    Default Wire
    The blue is the running light and the red is the turn signal. You can tap the blue wire into any wire that is hot when the key is on.
    Aug 2016
    Calverton N.Y.
    Default Amber fender LEDS
    Thank you all for your help.
    Got it all together LEDS are working fine.
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Thanks
    Add 4.8ohm 50watt resistors to each turn signal. But not in series, take one side of the resistor and attach it to the positive wire going to (say) the left turn signal. And the other side of the resistor too ground. Now do the same for the right turn signal.
    Now here's an important part, these resistors are going to get very hot, you are almost making a short circuit through them, so they have to be attached to metal on the bike. I used pipe clamps around the frame to hold them on
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Aug 2016
    Calverton N.Y.
    Quote Originally Posted by bcer960 View Post
    Ray
    Where can I purchase these resisters?
    Jun 2015
    Hampton Roads, VA
    Default DigiKey is a good place.
    https://www.digikey.com/short/qcf9dr
    This is a generated quick link to a 100W resistor for $7. Has a hole, so maybe you can find a place to mount. Just don't run the turn signals / hazards a long time
    Jul 2013
    Vestaburg Michigan
    There was a discussion a few months ago regarding resetting your flashers. I had hyper flash when I did mine. I believe I turned the flashers off and on three times , turned off removed key waited a few minutes. Turned power back on and mine reset and never returned. Not sure of the actual process, but you can do a search and try it. I think it was Fromm Lamont. Good luck !
    Jul 2016
    Kamloops B.C.
    Sorry, been on the road for two days, 1150 miles since yesterday morning. Just home from the Norcal rally.
    Yes, the resistors can be purchased from Digikey, or any electronic supply store. i got mine from a local shop in my home town.
    I reset the hyperflash the way Lamonster does it in his video several times, but it would only last a short while, and then the hyperflash would come back. The resistors fixed it permanently.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
