Results 1 to 17 of 17
    Nov 2015
    Myerstown, Pennsylvania
    Default Marbles and sand in the 1330....
    I apologize for trying to bring a little levity to a subject that has been bothering a few on this forum. That would be the noises that come from the 1330 while it is running. I did not feel that my light ribbing was out of place since this matter was brought up before. But someone else did. Therefore I shall endeavor to be more courteous & less insensitive to other peoples posts. And the answer to the tread that was removed can be found in the following locations. Thanks.
    http://www.spyderlovers.com/forums/s...ight=skeletons
    http://www.spyderlovers.com/forums/s...=engine+noises
    http://www.motorsportmagazine.com/op...-cylinder-cars
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Dec 2015
    Oakley Utah
    Quote Originally Posted by SteveLaoyster View Post
    I didn't think your response was out of line (at least the one I saw before the thread was pulled). I did think the OP's question was framed and worded in such a way as to beg a smart-ass remark!
    2014 RTL Platinum
    Aug 2013
    Northern California
    Default All I can Say
    I just don't have those noises!
    Default Agreed
    and I don't even have that motor...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Mar 2015
    forrest above Reno, Nv
    Default '''''''''''''''''''''''''''''''''''''Box of Rocks
    No offense is meant but the 1330 sounds like a box of rocks compared to both my V-Max and Valkyrie motors ( Valk has been sold ). The noise doesn't concern me any more. Especially after our 2 week trip with some high speeds and hot weather. ( not a drop of oil either)
    Kaos
    2014 RTS , Circuit Yellow
    Invalid Emails
    Apr 2017
    AZ
    Quote Originally Posted by kaos View Post
    Kaos
    After owning two Valks and two Goldwings I have to agree. The total lack of noise and vibration from those Hondas sometimes lent me to believe the engines had seized.
    Funny noises??
    I'm sorry: I have NO idea of what you are talking about...
    Nov 2015
    Kaos
    I agree that the 1330 is noisy compared to other engines. I didn't think mine was overly noisy when I got it. After looking around on here and on the internet I found that it's just the nature of 3 cylinder engines. You would think that balancing a 3 cylinder would be easy but because of having an odd number of pistons makes it difficult. Because of that you end up with more noise than an engine with an even number of pistons. Makes me wonder why Rotax didn't try to make a 4 cylinder engine to fit in the same space.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    I always felt the sound of the 1330 at idle was like a big diesel. It does have plenty of torque to pull in any gear at low speeds. Here, I have learned to live with it.
    Invalid Emails
    Apr 2017
    AZ
    You might not believe it but a driver once pulled up beside me at a light and asked if it was a diesel.
    Quote Originally Posted by RinconRyder View Post
    I do believe it.
    Have you ever pulled up to a SMART car in distress, and asked them if they needed a new flint? Sorry, the devil made me post it.
    Nov 2013
    Oro Valley Arizona
    "Never apologize, It's a sign of Weakness" John Wayne If it's good enough for John it's good enough for me!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Active Member MSa1956's Avatar
    Mar 2017
    Myrtle Beach, South Carolina
    Default Marbles
    I don't think my 2017 spyder RTL 1330, sounds like marbles and stuff I Believe it sounds like a Sewing Machine. But the Bike has a lot of torque and speed, I Love it, because its different.
    Mike
    Add On’s
    2017 Pearl White RTL
    SPYDER RAM Multi Mount
    Ram Mount Drivers cup holder
    Ram Mount passenger Cup Holder
    TRICELED Bar/Circle
    Brake Light/RGB LED
    Ground Effects Lighting
    Airhorn/compressor
    LED Head Lights
    LED Fog Lights
    K & N Air filter
    Two Brothers SR1
    Cat Bypass Pipe
    Easter Beaver Accessorie block
    USB pwr plug
    Removable hitch assembly
    Apr 2017
    North Central Florida
    Quote Originally Posted by MSa1956 View Post
    Mike
    +1
    The engine is quieter than most bikes I've owned.
    Maybe that's because it is shrouded in plastic.
    Active Member GaryinWI's Avatar
    Dec 2014
    Western WI
    Default Quieter
    My 1330 is a lot quieter than my last 106 Victory or a Harley Twin Cam. Just think of it as motor music and ride.
    2017 F3 Limited , Gloss Black with red and carbon fiber accents
    Nov 2018
    Claremore, Ok.
    Jack, if you still have all these vehicles you must be insurance poor.
    Nov 2018
    Claremore, Ok.
    Default I'm practically deaf,
    until I get my new hearing aids on Dec. 12th. from the V.A. but I have a 2014 Triumph Trophy with a 1215 inline 3 cylinder engine. It only weighs 800 lbs and will do wheelies if the ABS is turned off, and it seems noisy also. Oh, and it's damn fast, almost threw me off the first time I hit a bump and twisted the throttle too fast . So, I guess the noise might be a 3 cylinder symptom.
