"new to the spyder" battery ?????
Will this battery be ok on my 2012 spyder rt limited?
thanks in advance.
https://www.amazon.com/gp/product/B0...78MGMXY1&psc=1
Not even close to big enough. It it has half the cranking amps of the OE Yuasa battery. Get another Yuasa http://www.yuasabatteries.com/batter...D=B191&vID=115
Yuasa
i recommend 3 batteries: YUASA, YUASA & YUSAS.....
don't mess with 2nd rate anything... ALWAYS spend the extra few buck$, and you'll reduce your risk greatly of being stranded on the side of the road...
jmho
Dan P
SPYD3R
There you have it....
You can shop the price but not the spec's or quality...Try cheapcycleparts.com for one and ebay also has them. Google and you may find others just get the same one....
get the battery lamont carries
Lamonster's garage sells batteries. They are Motobatt, which in the motorcycle industry are considered to be a very good quality unit. His prices are very competitive, plus you support the community.
2020 RTL SE6
That says it's the correct battery for a 2012 RT but it's not. Your battery should be a size 24, not 14.
