Results 1 to 11 of 11
    Jul 2016
    Murfreesboro, tn
    Default Cleaning brake dust the lazy way.
    On a recent trip (2,000 miles), my brakes started squealing. All 3 sets. I have a 2008 GS SE5.
    What I want to do is spray the rotors, pads and calipers (on the MC) and power rinse at a local car wash.
    Any recommendations. Simple Green scares me....
    Thanks,
    Tntherapy
    PS-checked the pads and rotors, all are well within spec.
    Feb 2012
    Spring City,Utah
    why does Simple Green scare you? Not criticising just curious
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2012
    CO
    Quote Originally Posted by tntherapy View Post
    Thanks,
    Tntherapy
    shouldn't hurt the brakes at all using a power washer, no more so than riding through a large puddle or rainstorm. If you have access to an air compressor, you could blow out the brakes too - just don't breathe in the dust.
    JLohPhotos
    2008 GS , Millennium Yellow
    Jun 2010
    Las Vegas
    Brake cleaner is another alternative. I think it smells better than Simple Green.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    100 psi air pressure should clear out all the brake dust!!!!! My brakes squeal a little, but only under hard braking.
    Current ride: 2013 Circuit Yellow ST-S SE5
    washington state
    Make sure they are cool enough to clean.
    2012 Spyder RT SE5 Brake pedal mod
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Quote Originally Posted by ingramwc View Post
    My brakes only squeal when not braking hard, how can I tell which one/ones are squealing, I do wear hearing aids
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Northern Kalifornia
    Default I wear hearing aids too....
    Quote Originally Posted by wmh9680 View Post
    Put your hearing aids in your pocket when your riding and the squealing won't bother you.
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default 2 people !
    have some one standing in a parking lot , or empty street , enough room so you can roll by them and apply the brakes , do this at least 3 times !
    Jul 2015
    Dorr, michigan
    Use a car wash pressure washer on mine about every other day when we are on vacation. Spray the wheel cleaner on it, wash the bike, then hose the brakes down with the high pressure rinse, all brake noise goes away.
    Never had any problems with brakes or braking other than a squeal as brake dust builds up.
    2020 RT Limited , Petrol Blue
    Oct 2008
    Kingsport, TN
    100psi air pressure blows all the loose dust out also!!!!
