Results 1 to 15 of 15
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Default Question for those who trailer their Spyder
    I'm going to be trailering our 2011 RT to Florida from Canada this fall and back home in the spring.
    Distance is 1400 miles each way and we'll take 2 days to do the trip.
    My question concerns the air pressure in the trailer tires.
    Trailer is a Triton AUT1064 and is all alluminum and weights 400 lbs
    Tires are 175 80 13 bias ply load stars and max pressure is 50psi and max load is 1360lbs
    Based on my calculations I should probably be running anywhere from 30-35 PSI with the Spyder loaded.
    I've sent emails to both load star and carlisle tire companies with no response.
    Any help and advice is appreciated.
    thanks
    Greg
    Greg
    2015 RT Limited (White)
    Sep 2013
    Johnson, Vermont
    I may not be correct in doing this but I always run my trailer tires at the max. pressure. Doesn't matter what I'm hauling. In your case I'd inflate them to 50psi, load the Spyder and go.
    May 2012
    Panama City, FL
    Where are you going in FL? Dale
    Default Depends....
    Tire pressure also helps soften the ryde. You ryde at the max tire allowance with a light load you may have a bouncy ride. Not a problem for the spyder if properly tied down. Seeing as you will not be at full load capasity , spyder only, you are probably right with your calculations. If you are carrying more you may have to go bit higher...
    ​2012 RS sm5
    Jul 2017
    Quote Originally Posted by d.o.spyder-rts View Post
    Zephyrhills. This will be our first winter as snowbirds so we're pretty excited.
    Greg
    Greg
    Jul 2014
    Mint Hill, NC
    I agree with Gene. The trailer manufacturer used tires commensurate with the trailer max load. I personally would not go above 35 psi just for the sake of having a smooth riding trailer behind the prime mover. No sense in having the Spyder and trailer bouncing around more than is necessary.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member johnnyg's Avatar
    May 2010
    Ocklawaha FL
    Default tire PSI
    As a professional trucker [49years ]I would recommend you put the max of [50psi] in the trailer, it well do fine an your gas mileage to. I pull my two spyders on a tandem axel trailer just fine. Our last trip was to BRP 10th anniversary in Quebec just over 4,000 miles. Look on the side of the tire to see what they show.
    corbin Lamont cut seat with back rest, graphic gator,Chrome grips, trailer hitch,buttler mug, two brothers exhaust, painted center fender strips. center brake light, Led lights, tricLed fender lights
    May 2013
    Indiana
    Got a couple of questions before I can add my 2 cents to the discussion.
    1. Are the tires P-metric, Standard Load, or Extra Load?????
    2. What is the Load Index # of the tires(on the side wall after the tire size)??????
    Mike
    2021 Marsala Red Metallic RT Limited
    Jul 2017
    Quote Originally Posted by MikeT View Post
    Mike
    Not sure what question 1 means
    the load indes on the sidewall is 1360?
    Greg
    Greg
    Invalid Emails
    Oct 2015
    Dade City Fl/Minetto, NY
    Quote Originally Posted by Wrongway View Post
    Greg
    My wife and I spent six winters in Z-Hills. We went down from Oswego, NY. I purchased my 2015 Spyder RT from Tampa Bay Power Sports. I recommend them. Z-Hills is a great place to spend the winter.
    Default TRAILER TIRES
    Quote Originally Posted by johnnyg View Post
    ......Tires that are meant for TRAILERS ... NEED to be run at the MAX pressure stamped on the tire...they are made specifically for TRAILERS only .......... your trailer suspension is made for that purpose also ...it doesn't need help from the tires ......... under-inflated Trailer tires can easily OVER-HEAT and cause a BLOW-OUT ....... they also wear out quicker ...... If you are still nervous contact the tire maker Load Star ( well known brand tor trailers ) or google them .... Mike
    Jul 2017
    Thanks to everyone for the advice.
    I've added the Tampa Bay dealer into my address book in case I need service done.
    Still waiting to hear back from the tire manufacturers but I'm sure they're busy so I'll be patient.
    Pretty sure that they'll just say to run max psi all the time but I don't understand why when the 50 psi is for a load of 1360 per tire and my payload including the Spyder and trailer will be max of 1500 lbs.
    I'm sure that I'm missing something here but have no idea what.
    regards
    Greg
    Greg
    Active Member Eugene's Avatar
    Apr 2017
    Hamilton, Ontario, Canada
    Greg - for what its worth - I have pulled a trailer with a 900 llb Yamaha back and forth to Texas (approx. 6,000 kms round trip) with tires at max pressure. Done this for 11 years now and never had a problem. This is not a scientific approach - just what worked for me. I plan to do the same with the Spyder loaded this year!
    Jul 2017
    Quote Originally Posted by Eugene View Post
    Lol about the scientific approach. My wife says that I worry too much and over analyze everything.
    Therefore.........MAX pressure it is.
    thanks
    Greg
    Greg
    Registered Users classicvw's Avatar
    Aug 2017
    New Jersey
    I do know that as said previously under inflation is not good and will create a lot of heat.
    BUT, what I've done with 50psi max trailer tires is run them at 40psi. I've found this is optimal for a smooth ride with an 800 lb motorcycle on it. I've made approx. 8 highway runs of between 300 to 1000 miles to pick up various motorcycles and never had an issue. I keep the bearings well greased and usually check the hub's temp. with my hand at gas stops. Always been warm in summer heat, never hot.
