Results 1 to 21 of 21
    May 2013
    Indiana
    Default Didn't Quite Get My TricLED Wide VU Mirror Perfect
    Don't ya just hate it when a DIY install doesn't go as planned????? I got my right RT Wide VU mirror a smidgen off a perfect alignment to the OEM mirror. My question is: Can I use a hairdryer to "heat" the mirror's large adhesive area, and move the mirror into perfect alignment??? I don't want to cause more problems in my quest for perfection.
    Thanks for any and all assisstance.
    Mike
    2021 Marsala Red Metallic RT Limited
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I would suggest that you contact Cindy at Tricled for some solution.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Dec 2015
    Oakley Utah
    Quote Originally Posted by MikeT View Post
    Don't ya just hate it when a DIY install doesn't go as planned????? I got my right RT Wide VU mirror a smidgen off a perfect alignment to the OEM mirror. My question is: Can I use a hairdryer to "heat" the mirror's large adhesive area, and move the mirror into perfect alignment??? I don't want to cause more problems in my quest for perfection. Thanks for any and all assistance. Mike
    Try as I might, I was unable to get my Wide VU mirrors perfectly aligned. Nobody knows but me.
    2014 RTL Platinum
    May 2013
    Indiana
    That's how I'm playing it. Too much to go wrong trying for perfection(per tricled).
    Me too on both sets. Only we know.
    May 2012
    Panama City, FL
    I have a set also. I haven't put them on yet, tried a test fit and found it a little difficult to get the mirror lined up with the size of my hand-any suggestions? Dale
    Harrington, Australia
    Does the good old, "spray a light dishwashing/water mix on the mirrors", which allows a short period of ability to slide before it dries out, not work with the Tricled install?
    HeliBars Handlebars
    Kenda Kanine rear.
    May 2012
    Panama City, FL
    Not sure, you have to clean the oem mirror with an alcohol pad before installation. I don't know the effect of the solution on the mirror adhesive, it might not hold. Dale
    Quote Originally Posted by d.o.spyder-rts View Post
    I did the test fit thing also. Put folded cardboard on the side and bottom so they would line up "almost" perfect when I let the stickum do its job.
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Would using a suction cup on the Wide Views help the install positioning ?
    May 2012
    Panama City, FL
    Quote Originally Posted by HayRog View Post
    Not a bad idea, it could help getting the mirror lined up better. Dale
    Default TRY THIS OR THIS
    If you put cardboard shims around your OEM mirror, when you put in the TriCled it has no other way/place to go but inside the shim area ....... OR ..you will have to test this before you try it because I don't know how sticky the Adhesive is ....put a piece of WAX paper on the adhesive to see if it sticks first ........if it doesn't you can put a slightly oversize piece on the OEM mirror then fit the TriCled on top and you can position it and have someone pull the wax paper out ..... I used to do this with Formica and Contact cement ( you did not want to make a mistake in alignment with that stuff
    Jun 2010
    Las Vegas
    I was very nervous when I installed mine but I guess I got lucky and they went on with no issues. But when it came to installing them for customers I was more than a little nervous, I probably lost sleep worrying if I would get them on right or not, I even thought about asking customers how they would rate themselves on pickiness. If they were too picky I would give them a discount and let them do the install themselves. So far so good!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Danbury Connecticut
    Here's what I did, and it's perfect. Perfect I tell you, PERFECT.
    First dry fit the new mirrors to make sure you haven't reversed the left and right mirrors. Next be sure you have the orientation correct for each mirror, up and down, left and right
    Take all the red tape off the back. Holding the new mirror at an angle of about 30 degrees, line up the outside edges of one corner. I did the upper left.
    Next, line up the left side of the new mirror to the old mirror. Just the edge.
    Next, line up the lower left corner. You can still remove the new mirror without damage if you don't get these steps right.
    If you're not satisfied, try the line-up again.
    Once you're satisfied with the line up of the left edge, slowly push down on the mirror, left edge to right. You're now committed, and it will fit perfectly.
    Easy Peasy. Even an old spastic like me can do it.
    As always, my free advice comes with a double our money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Active Member Bike-O-Din's Avatar
    Apr 2012
    Cross Junction, VA
    Default Here is the trick I used.
    I have "fat finger disease," and found it very difficult to get a grip that I thought would let me place the mirrors in the correct position. As you know, you only get one chance to get it right with the 3M tape. There is no turning back if you put it down in the wrong place.
    So, I created these little "handles" using painters tape so I could use both hands and place the new mirrors in just the right spot before pressing them into place. It worked like a champ!! I hope this helps someone when doing the installation.
    2011 RT-S , Silver
    May 2013
    Sacrament0, CA
    Like this idea ^^^^ simple and effective.
    There I was, waiting for my Wide Vue mirrors to arrive, worrying about how I would get the Tricled mirror aligned correctly after reading all the above posts. Well that was wasted time, wasn't it . The F3-L Tricled mirrors have a lip around the outer edge that slips fully over the current mirror, meaning even a klutz like me can't misalign it! I just KNEW there was a reason I decided to buy an F3-L.
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    thats how i lined mine up on my rt. try it dry, line up an edge, and put
    it on .dont overthink it.
    [joyce & irvin toms]
    May 2013
    Sacrament0, CA
    Default Suction cup method
    Mirrors arrived today --- nice, nice
    Installed in 2 minutes - and WOW !! Amazing field of view
    Thanks you Cindy and TricLed
    Used a 2" suction cup to hold steady - spot on alignment
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    I love my new mirrors! Not only do I see new lanes but I also don't look so fat standing in front of them. "Honey? DOes this mirror make me look fat?" .
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by Bike-O-Din View Post
    I also used painters tape to install mine except I made a loop with the tape that allowed me to hold and align the mirror better. When I did a dry fit I found it difficult to hold the mirrors without dropping them and came up with the idea of using painters tape.
    This is one of my favorite mods, been using them since May.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
