Rear Shock - Adjustable Replacement??
ST Team,
2013 STS, rear shock seems very stiff riding solo. Ride is much better 2 up. Anyone replace rear shock with an adjustable??
Spyderfish
I don't own an ST but on my RS the rear shock has a "ring" at the bottom that can be adjusted with a wrench to different positions to adjust the shock spring setting. When I ride 2 up I jump it up 3 notches. Does the ST not have this?
Agree...
If yours is not adjustable there are a few out there but not cheap. Fox, RaceTech, Elka, Progressive, Wilber etc. You could find an adjustable one from the RS, GS, RSS models...
shock options
I never regretted spending the bucks to have Cogent Dynamics in Asheville, NC, build a rear shock for my F3-S. Huge improvement in ride quality, and simple remote pre-load adjustment (no more locking rings!).
They are good, honest folk with whom to work.
Pete Tamblyn
Cleveland, GA
2020 F3 Limited (black)
Time Out XL1800 cargo trailer
2019 Royal Enfield 650 Interceptor
2018 Kawasaki Versys-X 300
2013 ST (sold)
2015 F3-S SOLD
2014 RT-Limited (cognac) SOLD
No adjustment
Front and rear springs not adjustable
We put an Elka on the rear of our ST Limited. Ours had the Fox adjustable shocks up front so I just cranked up the spring preload to the max.
Elka Model Number
GearHd,
What year is your STL? Do you know the model or style of Elka shock? Did you install it yourself, big job? Was there a big difference?
Thx,
Spyderfish
Doesn't Matter
Originally Posted by spyderfish
GearHd,
Thx,
Spyderfish
All ST models are virtually the same mechanically, the year doesn't matter they are unchanged within the 3 years of production.
