Driving Lights
Where is the best place to mount driving on the front of a Spyder oor a-arms top or bottom!
[QUOTE=RudyB;1294278]Where is the best place to mount driving lights on a-arms top or bottom
Depends....
Depends on the model a bit...
FB_IMG_1440825275507.jpg but I have seen most on the A arms....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Originally Posted by Chupaca
Like where you have the lights. I like the skid plate too. One of our vendors make that or yourself?
2014 Spyder RS-S SE5
Mods:
ST Limited Wheels
RT Handlebars
Ultimate Seats ST Midrider
Lidlox Helmet Lock
Show Chrome Brake Pedal Extension
Excelvan X-Grip Cell Phone Holder w/USB Charger
Much more to come......
Ryder:
6'-1" - 205lbs - 32"IS - 34"Reach
LITES
mounted mine using the bolt that attaches to the fender support... works well...
Dan P
SPYD3R
Figuring that being seen was even more important than seeing: I went with a lighted Bumpskid!
I have the bump skid LEDs (sort of) also. About 25% of mine quit on one side and now other lights intermingled with the rest have quit working. Now it looks like a lop-sided, gap-tooth creature going down the road. Not real happy with the lack of longevity of the LEDs. I will probably just unplug them when the spirit moves me..... But, they looked great and made the bike really visible when they worked.
Semper Fi
Doc Riverside figured out what was wrong, and how to fix it!
Hi canamjhb, we carry replacement LED strips. This one is wider LED strips, much more durable, it won't go inside the groove but will go on top of it for the whole perimeter.
https://www.tricledusa.com/_p/prd1/3...ed's-only)
Not sure what you mean...
2014 RTL Platinum
The original led bumpskid was one long strip, it's now split into 2 separate strips that are fed from both sides. I saw some being replaced at Spyder Rendezvous and they're much better.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Here's Cindy's LED driving lights on an F3-L, mounted to the existing fender bolt.IMG_0482.jpgIMG_0486.jpg
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
good ideas on the mounts
Where are you getting power?
Tap into the position light wires?
2017 F3, SM6-basic black, plain and simple
I think that you could actually just tap into the wires that supply your front fender lighting...
Originally Posted by ofdave
good ideas on the mounts; Where are you getting power? Tap into the position light wires?
I believe both Lamonster and TricLED (and probably some others) have instructions with their product which suggest where to get the power from. Maybe you should buy the lights first and then ask questions if the vendor doesn't answer them?
2014 RTL Platinum
not a bad idea,
but like some others, I am not buying plug and play lights but installing my own as did spyder3.
So it'd be nice to know where to tap, but Bob is likely correct.
HAND'S UP:
The only sure way of getting rid of bad habits is to create good ones.
AND, by the way, this will not happen on auto pilot.
It's time for a YOU-turn!!!
POWER SOURCE
