Front tire size F3S
Anybody out there running a 175/60/15 size tire on the front? 2016 F3S
You will most likely find that the aspect ratio (side wall to /width) of 175/60-15 will be too tall. I run 175/55-15 Hankook Ventus V4 without any issues.
HEIGHT OF TIRE
Height of not tire is not material, we are very limited in what tires will fit and the height isn't the determining factor ( and I do know about aspect ratio ).... because the fender goes up & down with the tire, that ratio or distance never changes .... Mike
