Results 1 to 20 of 20
    May 2017
    Mesa, Arid-Zone-A
    Default Securing Nolen helmet
    I have a flip face Nolen helmet. It does not fit in any of the Spyders compartments (contrary to advertisements). The helmet chin strap has a ratchet clip with no open D ring. Has anyone found an easy and effective way to secure this kind of helmet to the bike? Thanks.....
    Semper Fi
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default We use a "Helmet Guardian" and Helmet T extensions
    Purchase Helmet T extensions (come in pairs) that fit through the latch end of the Nolan helmets. Then you use the T extension to lock it on your bike using a "Helmet Guardian" lock or something similar. We've been doing this for years....
    Here's some info:
    Helmet Guardian (it secures to your license plate mounting - see picture below). www.helmetguardian.com/index.htm (copy & paste in your address bar)
    Nolan Helmet T extensions: Nolan & Schuberth Helmet Lock Extensions (993-136) MADE BY ADD ON (I found this on ebay)
    We use the helmet T extensions with both of our bikes. The Gold Wing has built in locks under the trunk, but you'll need to add something to the Spyder (like the Helmet Guardian) to secure the helmets to the bike.
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Lidlocks
    They advertise on this site.
    AJ
    Quote Originally Posted by canamjhb View Post
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default Lidlox
    Lidlox is the way to go. I have a Shark Evoline helmet with the rachet strap- no issues using lidlox.....
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Default Nolan Helmet in the Frunk
    Not sure what Nolan helmet you have but my N104 XXXL does fit in the frunk of our RT-S. You have to ensure the frunk is empty on the bottom and place it in visor 1st. The XXXL is the largest modular helmet Nolan makes so you should be able to with some patience.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Active Member cheska's Avatar
    Apr 2013
    Vancouver Is. BC /Arizona
    Default N 44 and N40 full
    Wifes N44 fits in frunk. My N40 fits in empty right saddle bag. We also use lid locks they work great and are easy to install.
    900 Ryker Wifes
    Dec 2015
    Oakley Utah
    I think you mean the neck strap that secures the helmet to the head. It's ratcheting and doesn't really have a place to run a security cable or other device through like the D-ring of traditional helmet strap systems;
    There's a picture of it here (on a different helmet) http://www.nolan-usa.com/products/n2...ed-junkie.html
    2014 RTL Platinum
    We use Nolan helmets exclusively. All our N40 versions fit in the frunk of our RT's. We also carry "small stuff" in the frunks. I don't like fiddling with the top trunk or side saddlebags--so have never went there for helmet storage.
    Your profile says RTL--so I think your covered.
    Bossier LoUiSiAna
    Quote Originally Posted by PaladinLV View Post
    Lidlocks
    AJ
    X2 was out on ride with a bud that has a nolan & he forgot his lock piece, was able to use my spare T piece for lid lox & fit np, off to lunch we went.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Feb 2012
    Spring City,Utah
    there are little tabs that stick out from the plastic when you have your seat up. If you run your fingers along the inside edge you will feel them. Open your chin strap as much as it will go and you can hook it around that tab then close your seat. How the helmet is secured is not really visible so you are as safe as you can be with honest people. There is no safety with dishonest people.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2017
    Mesa, Arid-Zone-A
    Thank You all for the much needed advice. I did manage to get the helmet in the frunk but had to take EVERYTHING out including the owners manual. Even then it is a very tight squeeze. Not as convenient as I would like. Not even close to fitting in the side bags. (Did I mention I have a big ol' fat head and my Nolan outer shell is the biggest they make) Looks like Lidlox or Helmet Guardian are my best bet. Just need to make sure the T extension will fit through the Nolan helmet latch. I know my Goldwing T will not.
    Semper Fi
    Idaho
    For 11 years now I haven't worried about locking my helmet. I just set it on the seat and throw my jacket over the top. Hasn't been stolen yet, knock on wood! At hotels I take it into the room, just to be extra safe.
    2014 Copper RTS
    Member jojo's Avatar
    Feb 2017
    Columbus, Ohio
    Default Nolan helmet
    My Nolan N-102 modular fits in the frunk fine. As a matter of fact, my Nolan and my wife's open face (with a windshield) both fit in the frunk together.
    I leave the facemask open on my Nolan, and put it in the frunk sideways (face towards the right side of the bike), then puts my wife's on top of mine.
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    I use a light weight cable lock and run it through the chin bar on both helmets, through one sleeve on each jacket and then through the passenger grab handles. Put the helmets on the seat and the jackets on top of them. Been doing it this way for years. at night everything goes in the room.
    Right-hand side storage compartment...
    (close everything up on the helmet tightly...)
    Visor facing toward the front of the bike: slide it into the compartment on it's side, and neck opening first.
    If that doesn't work: Lidlox work fantastic!
    The size question did not come to mind. We are of course Nolan mediums.
    RT-S PE#0412 TicketBait's Avatar
    Dec 2009
    Santa Monica, CA. USA
    My Nolan helmet I use to have was a model 103 I believe could be wrong. Purchased a handle bar lock with a "T" ring bar to secure. Can't show you pictures since photobucket "f'" d me
    Feb 2015
    Las Vegas
    Lidlock T bar fits a Nolan no problem, cause one of my helmets is one
    AJ
    2014 RT-S
    2014 RT/S , Black
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    Quote Originally Posted by fjray View Post
    +1 to this
    and you keep the stuff in the bags
    if you don't use a full face, you can feed the cable through the d-ring on the helmet.
    or, like on my modular, between the chin bar and face shield
    2017 F3, SM6-basic black, plain and simple
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Ditto for me and Deb ---- for 20 + years.
