Results 1 to 6 of 6
    Aug 2015
    Cleveland, GA
    Default F3 shock on a 2013 ST?
    These are on eBay right now:
    http://www.ebay.com/itm/Brand-New-Ca...5XyZuR&vxp=mtr
    Wondering if anyone knows if they will fit a 2013 ST (length seems the same and the bottom mount appears the same width on each machine), and if they are significantly better than the "Fox Podium" shock sold for the ST?
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    I would think they would fit and work very well. Same frame/suspension components on both machines. Just get an eye to eye (centered) measurement of both and you will have your answer.
    Aug 2015
    Cleveland, GA
    Default eye-to-eye measurement? A little help please.
    I have researched that the eye-to-eye (ETE) measurement for the F3 shock is 17 11/16"
    It will take removal of some bodywork to measure the ETE on my ST, and my time is severely limited. If someone can provide the ETE distance for a 2013 ST front shock, I certainly would be grateful.
    Thanks.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Aug 2015
    Cleveland, GA
    Default straight from Elka's mouth
    So, I asked the smart folk at Elka if the F3 and ST could use the same shock. Here's what I was told:
    It's almost the same...
    Front 2013 RS
    17.677" long
    Front 2015+ F3S
    17.638" long
    Spring rate and spring length is different. The RS use a 10" spring and the F3S use an 8" spring.
    Spring rate for the RS is 225pnds/in
    Spring rate for the F3s is 320pnds/in
    Regards,
    SEBASTIAN LEVESQUE
    Sales Representative
    Front 2013 RS
    17.677" long
    Front 2015+ F3S
    17.638" long
    Regards,
    SEBASTIAN LEVESQUE
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
    Default Several points...
    One is the length, then the mounting then the spring. If you get the first two the third is adjustable. Then the tedt ryde will tell you the rest of the story...if you do it give us a report.....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2015
    Cleveland, GA
    Default decision
    I opted for a very plain vanilla decision.
    Even though it seems the lengths of the two different shock applications are essentially identical, given the wide variance in spring length and "poundage" between the F3 and the ST shocks, rather than chance buying something that could have been wildly wrong I took the simple cheap upgrade:
    a set of lightly used 2015 ST shocks (Fox) off eBay for $195. Should remedy the notoriously inadequate original shocks BRP put on the 2013 ST, though still far from being the ultimate choice I could have thrown big bucks to obtain.
    If I decide this bike is a long-term keeper, I'll go see my friends at Cogent Dynamics in Asheville, NC, and let them do the job with science rather than guess work.
    Pete Tamblyn
    Cleveland, GA
    2013 ST (sold)
    2015 F3-S SOLD
