Results 1 to 12 of 12
    Apr 2017
    Queensbury, NY
    Default Anyone Ride With an Old iPod Touch?
    I've got an old iPod Touch which still works fine but doesn't support Bluetooth, so streaming isn't an option. I'd like to use it to listen to music while I ride (by simply putting it in a pocket and connect wired ear buds to it.)
    The problem is that the Apple ear buds are very uncomfortable for me, so I'd like something thin and flat (preferably outside the ear) that might fit well within a snug fitting helmet. Does anyone know of anything that might work for this?
    Thanks.
    Active Member pwm's Avatar
    May 2013
    Knoxville, TN
    I did with my 12 RT. I simply plugged it into the trunk connector.
    2017 F3- Limited
    F4 23" Windshield, Ultimate Backrest, Spyder Cuff, SpyderPops Bump Guard, Sena SMH10 Intercom, BajaRon Sway Bar, Baker Cup Holder, RT-622 trailer w/Spyder Pops Bump Guard
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    The Sena 20S has an aux port where you could plug in a cable from the headphone jack of the iPod to the 20S and listen thru the helmet speakers.
    Oct 2016
    Faribault, MN
    Ask Motorcycle Dave, Sponsor here, he's got the goods! and experience...
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Apr 2017
    Queensbury, NY
    Quote Originally Posted by DGoebel View Post
    Will do, Thanks!
    Active Member Slowpoke387's Avatar
    Apr 2017
    Enfield, CT
    Don't you have an L? with the stereo? Why not just plug your charging cord into the usb port in the upper glovebox? listen to it through the radio. Unless you have the T with no radio. But I thought you had the L.
    Active Member kywinger's Avatar
    Sep 2015
    Carrollton, KY
    I use an Ipod touch.
    Use the cable in the trunk and listen through the radio.
    2015 Red Pearl RT-S
    EXO2 heated Vest/Gloves
    BAJARONS sway bar
    TricLEDS side markers
    Xenon Depot LED Head & Fog Lights\
    Missing Belt Guard
    Bump Skid
    M2 Shocks front/rear
    Russel Day Long heated seat
    Dec 2015
    NE Ohio
    If you want earbuds and ear plugs, try plugfones. I have an RT ad use the connector in the trunk. I use the plugfones on the 2-wheeler.
    Apr 2017
    Queensbury, NY
    Quote Originally Posted by Slowpoke387 View Post
    Yup - I've got the T with no radio.
    Apr 2017
    Queensbury, NY
    Quote Originally Posted by KosherKid View Post
    Hmmm.... That looks like it's worth a try. Thanks!
    Feb 2009
    Chiang Mai, Thailand
    There are many Bluetooth adapters that you can plug into the headphone jack and even the charger port on the ipod and then use it as Bluetooth, you can find may on Amazon. I think Lamonster sells a Bluetooth thingy also just cant remember what it does.
    Danbury Connecticut
    You can try making your own custom earbuds.
    http://www.earfuze.com/
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
