Results 1 to 18 of 18
    May 2016
    Cartersville, GA
    Default Is the only Cat bypass benefit heat reduction??
    Is the only benefit of a cat bypass the reduction of heat........................ and maybe a few pounds...... especially in my wallet......
    It'll definitely change the sound of your bike... If that's an important thing for you...
    Apr 2017
    Boulder City
    Is there any performance increase in torque or hp?😳
    I've never seen a Dyno-test; to prove or disprove anything.
    Very Active Member tehrlich's Avatar
    Jul 2015
    Spicewood Texas
    I love the change. It sounds a bit throatier, but not that much louder. Not even close to any V twin. I have the stock RT Limited muffler.
    I would guess that dyno tests don't show much, but I could feel the difference in the range of my needed shifting.
    Plus... you wouldn't believe how heavy that secondary muffler is. Glad to have that weight off. Probably feels faster now just by removing the weight!!!
    2015 RT Limited: Fox Shocks - RonJon swaybar and links - BRP Comfort Seat - BRP Triaxis handlebars - Yokohama tires (26psi fronts 28psi back) - Centramatic wheel balancers - BRP belt tensioner - BRP Short windshield - CATdelete/Spyder1 attitude exhaust - Lamonster footpegs - sintered brake pads - LED TRYCLED lights - BumpSkid
    2015 RT Limited , black
    How much weight? 20 pounds? maybe 25??
    Active Member Schwingel9's Avatar
    Jun 2017
    Wi
    I just installed one. Sounds great, less heat, but i smell like a tail pipe.
    Quote Originally Posted by Schwingel9 View Post
    Default " CAT " WEIGHT
    Well just for you Bro ... I walked down 13 steps ...dug out my old CAT ( from an RT 1330 ) and it weighed 18 lb. 4.3 oz.... on a certified Fish Scale .......You were sort of close ...... Mike
    Jun 2014
    Lowrys SC
    Quote Originally Posted by Ramrover View Post
    I had mine on the v twin and while I did like the sound, it became a little raspy right at the rpm to shift. Wasn't really crazy about that. It did seem to pick up a little torque in the mid range but not a lot. And I didn't see that much heat reduction. Put the oem back on and installed a Two Bros pipe, Sounds Great!! That's what I was looking for. Deep and throaty!
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    You don't have to change the litter box anymore
    2019 Rally , Black
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    I like the idea of the cat delete
    my concern is what does it do to the warranty?
    2017 F3, SM6-basic black, plain and simple
    Jul 2011
    Cleveland, Ohio
    Default Threw the By-Pass out, brought the Cat in...
    I put my Cat back on. Could not stand the NOISE any more. I definitely got my low end torque back. Taking off from a traffic light is now a fast RESPONSE. With the Cat-Bypass on it was a pig off the line. There was a definite LOSS of low end torque, no I did not add the baffle, the increase in noise was enough for me to take the By-Pass off.
    Chris
    Jun 2017
    Wi
    I did not lose any low-end torque. I love the sound. The smell is the only thing that's a bit agitating.
    Jun 2016
    indpls in
    Default what
    what smell ?
    Apr 2016
    St. Charles IL
    Hope you didn't hurt yourself
    Bill W
    2019 F3 LTD
    Nov 2013
    Oro Valley Arizona
    That story sounds pretty fishy to me!
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jun 2017
    Wi
    Quote Originally Posted by fatboy View Post
    what smell ?
    Exhaust fumes. Especially in garage.
