How to move rear tire over in an enclosed trailer
Just bought a 6 x 12 enclosed trailer for my can am rt5.. i have to move the rear tire over about 6 inches to get another smaller cycle in but am unable to because of tight quarters.. anyone have any ideas on how to slide over on a wood surface??????
wheel dolly
You could pickup an inexpensive wheel dolly at harbor freight? Jack it up in the trailer and rest the wheel on the dolly.
https://www.harborfreight.com/catalo...&q=wheel+dolly
2014 RT-S Pearl White
so what type of lift would i buy and where would i place it... just bought my rt5 so i am new to this....
Just get the small HF floor jack. Jack your spyder's rear tire up, scoot it over and let it down. By all means, don't leave your spyder's rear tire on a dolly while you're driving down the road.
Check the link I sent
One of of the wheel dollies in the link above, looked like it had a built in lift. May be the answer to your whole problem?
Originally Posted by spyderyooper
ok will try... thanks
Get a piece of carpet large enough and fasten it under where you rear tire will be. Get some plastic furniture sliders and put them on a smaller piece of plywood and put where your rear tire will be. Drive on it and you can easily slide it by hand. I have seen this done so another bike can be loaded.
ok thanks.. another good idea
Ya hey der Yooper, ya just grab the passenger handrails and give it a heave ho.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Third world ingenuity...
Put her in neutral, release the park brake, push a shovel under the rear wheel (it will roll under) shove it over (slides on the shovel blade) pull shovel out... when you work alone you need those little extras to help you...
2012 RS sm5
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
I use a piece of corrugated cardboard under the rear wheel. Place the cardboard under the rear tire as you are rolling the Spyder into position. The cardboard had reduced friction and allows the tire and backend of the Spyder to be moved reasonably easy. Move the Spyder off of the cardboard and then roll into your desired location to strap it down.
Wayne
pauly1 - SpyderDeb's 'wrench'
2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
IBA #48220 SS1000 BB1500
2015 F3-S , OEM na Basic Black with Custom Wrap
Proper application of explosives ought to get it done
Also my way
That's exactly how I do it...And it works every time!!!
PASSENGER GRAB RAILS
if that won't work
If that wont work, you can use a ratchet tie-down to help slide the wheel. Just attach it to the rear wheel with a loop and crank away. If you need more leverage that that, a pair of visegrips on the lever will help. Add that to any of the friction reduction solutions people have posted and you should have an easy time of it.
explosives
As we used to say in the Army, there are very few problems that a proper application of explosives won't solve.
Saw a guy move the back wheel in an enclosed trailer with a furniture slider like you buy at Lowes. Hard part was placing the slider it right to pull the back wheel up on it. He then strapped down thr front wheel and slid it over with very little effort.
Grab a passenger hand rail, shove the back end down, and as it rebounds, just pull it over on the rebound. All in a swift motion of course...Piece 'o cake.
2021 RT Limited
Spray some WD-40 on the floor and it will slide easily.
Friend of mine used something similar to this. His is more like a standard floor jack with 2 bars that are spaced out to fit on each side of the tire. He jacks it up a little, moves the rear of the Spyder over to the side of the trailer and drops it back down. It makes easy work of the job. So easy in fact, I've seen his wife move it over by her self.
