Results 1 to 2 of 2
    May 2016
    Ontario, Canada
    Default Reat trunk 12 v plug
    Hi folks,
    I have noticed that on the rear 12v plug (left side) the nut has come off the 12v plug and the plug is free to fall out. I think this was done by the dealer when they installed the sat radio??? Any ideas on how to access the back side of the 12v cigar plug. Hoping not to have to spend 1.5 hours driving to take it back to the dealer.
    Thank's in advance.
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    You have to remove the top colored plastic piece that wraps around the rear trunk. Then you need to remove the three screws from inside the left side of the rear trunk that holds the left speaker enclosure. Once it is removed the back of the outlet is right there.
