i went back to halogen. went with some philips bulbs. i tried the ebay ones.
shoulda gone with cindys or lamonts maybe. lit up the road signs but wasnt pleased
w/light on the road. even tried adjusting. run it up and down and worked on them.
with the new halogens i have all the light ill ever need , side and front. to each their
own .im leaving mine alone for now. the leds sure do make you visible, though.
2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
and some little stuff. setback utopia backrest, baja ron
sway bar, oem adj. air deflectors, marlin gps compass,
lamonster fbb foot pegs[modified brackets], lamonts
vibration damper, rock guard, and side case stiffener kit,
. brp comfort seat. , fomozas and
altimax, magic mirror mts, and wide mirrors.
[joyce & irvin toms]
HALOGEN BULBS
Irv I now have a few sets of them ( halogen's ) that I was going to throw away ....... I save them and give them you if we are in the area ...... just let know ...... Mike
thank you but for what little night riding we might do these are great. ive been in the body
shop business since 1991, so i do know a little about h/l alignment. i have a set of used
h/l's and set of new fog lamps too. these are the ones joel talked about. they might
work great foe someone else. maybe im not used to led's on the road.
i do have 2 large led aux lamps on my honda rubicon for snow plowing .they
are awesome!
Re fog lite replacement bulb
Originally Posted by jcthorne
Guess my memory is getting bad. Swore I watched a vid. Must have been for the F3.
Still, by removing the mirror and the upper body panel, one screw and 3 push pins on the left side of the frunk the trim around the fog light will move aside enough to get to the lamp from above. You do need to disconnect the air intake tube. Its a rubber hose that will compress out of your way once removed from the air box end. I usually have my left hand in from the top, right hand in from the bottom through the wheel well to help guide. Its done by feel but there is plenty of room. Usually takes only a half hour for both fog lights including body fastener removal. This is when already doing the headlights as the side panels are already off to get to the head lamps.
What is the stock replacement fog lite for the the 2014rts thanks
