Results 1 to 11 of 11
Thread: Horn problem?
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Radio problem?
    Have a 2014 RTS SE6
    Recently during my rydes I have noticed that when I try and get another station on the radio, the radio only goes up .1 channel at once. By this I mean, 105.7 then 105.8, 105.9, when in the recent past the radio would go to the next most powerful station. My question is, " Has anybody had this problem before"? Also, I have noticed that when the Spyder down shifts, there is a noticeable clunk, when in the past there was no noise.
    Question. Could an old battery be the cause of this. This is still the original battery. Thanks in advance.
    2011 RT-S SE5 Viper Red
    2014 RT-S SE6 Cognac
    Bajaron sway bar w/ aluminum heims
    Custom Design HM Brake light
    Custom Design Red front fender lights with turn signals
    Lidlox
    Corbin arm rests
    2014 RTS SE6 , Cognac
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    Check oil or shifting in too low of rpm.
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by viperryder View Post
    Have a 2014 RTS SE6
    What am I missing... thread is titled "Horn Problem" and I see nothing in here about a horn.
    2020 RT Limited , Petrol Blue
    Default YOUR ISSUE
    Have a 2014 RTS SE6
    I'm pretty sure you have ( accidently ) changed your Radio from Seek to Manual mode ..... but I could be mis-taken ...... Mike
    Oct 2011
    Ohio
    Thanks, will try and find how to change back. Had an idea of this, but did not know if possible.
    Lidlox
    Corbin arm rests
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    How is your horn doing?
    Mar 2015
    forrest above Reno, Nv
    Thumbs up Beep, beep...............
    "Beep, beep-- Beep, beep------his horn went Beep, beep, beep"
    https://www.youtube.com/watch?v=enqNl7tdLR4
    2014 RTS , Circuit Yellow
    Nov 2013
    Central Texas
    Aug 2017
    Chesterfield, VA
    Quote Originally Posted by kaos View Post
    Nov 2013
    Central Texas
    Dang kaos, you beat me to it!
    Mar 2015
    Quote Originally Posted by oldguyinCT View Post
    The big Great Dane can be pretty quick after the early morning coffee.
