Lugnuts
What size lugnuts are on a Spyder and the best way to get them off without breaking or striping the lug?
21mm or 13/16". good socket with a breaker bar
Lugnuts are 21 mm on Spyder
Lugnuts are 21 mm on Spyder, and a 13/16 spark plug socket is thin wall and will fit a little tighter and do fine to remove and then when you go back with clean wheel and nuts, torque to 77 ft-lb and you'll be good to roll.
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Use a six point socket for best grip on the nut.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Lug nuts
And turn them left loosey
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
I like even numbers and torqued mine to 80#s. I believe to specs call for 80 +/- 3#s
Semper Fi
SpyderLovers Sponsor
Easiest way is with an impact gun air or elect.
21 mm six point socket or 13/16
IF you know what you are doing. I have made a lot of money over the years from folks who went after their bikes with a shiny new impact gun
Lug nuts
The reason I asked was I only had a 3/8" rachet, I put a big wrench on the end of it and broke the rachet. Had to borrow a 1/2" to do the job. Got my centramatic balancers installed ok.
Eight foot-pounds and 3/8 inch Chinese steel do not play well together.....
Semper Fi
