Results 1 to 21 of 21
    Active Member Rigsby's Avatar
    Sep 2016
    Uk
    Default Lifting my Spyder above my head
    Now you see it......
    Now you don't.....
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    David Copperfield pay a visit?
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    May 2016
    Nice setup, by the way!
    2013 RT-S SE 5
    Default Very cool
    Space saver parking.... very nice set up...congrats
    ​2012 RS sm5
    Sep 2016
    Uk
    I have got a full 8 inches of clearance between my car and the lift and even if the car is in off road height I have still got plenty of space so they can't make contact
    Active Member RTman10's Avatar
    Jun 2017
    Nottingham UK
    That is something else. Well done.
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    excellent idea
    have always wanted to do that but my garage ceiling is only 8' so it's not possible.
    have seen a few who keep a second (hobby) car on a lift like that
    am envious
    Dec 2013
    Quote Originally Posted by Rigsby View Post
    Now you don't.....
    I SOOOO want one of those things!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2016
    Uk
    Thanks for the comments, it took quite a bit of careful measuring as the space in the front of the roof isn't that big. Had a nightmare actually importing the lift due to problems with other items in the same container that customs weren't happy with, leading to a delay of about 4 weeks in the end. Relatively easy to put the lift together once the single post was in the correct position. The length of the bed is adjustable and I have filled in the central section with lengths of 6" x 2" treated timber, removable just in case I want to work on it at any time (like fitting a sway bar).
    All in all I'm very pleased with the way it worked out
    Jul 2014
    United States
    Well done!!
    SpyderLovers Sponsor F4 Customs's Avatar
    Nov 2012
    Twinsburg, Ohio
    Default Spyder Lift
    Great Job! I really like it.
    Don
    F4 Customs, Inc.
    "The Motorcycle Windshield Folks"
    941-347-7496
    sales@f4customs.com
    <a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I cannot help but wonder about the roof trusses and how you worked around them!
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Sep 2016
    Uk
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    Well I was quite lucky really as the house has a wrap around extension which means there was loads of roof space in the centre and far end of the garage but I still had to move some of the horizontal beams higher up into the roof space. The area where there is least height is just inside the door so one of the joists needed to be cut out and re strengthened so that the rear lights and also the drivers backrest had enough clearance. I wanted to make sure that the lift could go to its maximum travel without risking any potential damage. The lift goes to its maximum and then you can lower it onto one of its mechanical locks for safe storage or working height. All in all it has worked out well
    I changed the brake rod a couple of days ago and it was great to be able to work at the right height rather than laying on the concrete floor with bits falling in my eyes and keep having to get up and find tools etc......luxury
    Dec 2015
    Oakley Utah
    Ingenious. Good job!
    2014 RTL Platinum
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Default I wish...
    I wish I was as rich and clever as you folks! I feel blessed to put fuel in the Spyder!
    Well done!
    ~Bud~
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
    Idaho
    Probably less expensive than a new garage or an addition to the existing garage!
    2014 Copper RTS
    Idaho
    Did you accidentally reverse the photo? The car's steering wheel is on the wrong side!!!!
    2014 Copper RTS
    Sep 2016
    Uk
    No wonder I've been having trouble, I thought the tracking was out
    Sep 2016
    Uk
    Hi and thanks for the PM. Having trouble with the pictures using PM so put them here
    This was the reinforced concrete base, 3500 lb mix reinforced with rebar and a minimum of 6"
    although I needed a raised plinth to get the required height so I had more than 12" in the end.
    This is the main pillar before being centralised and secured using 5x concrete anchors
    Next was to secure the 6"x6" cross beam
    IMG_789.jpg Then add the wheel wells and fill the centre with 6"x2" timbers.
    Once I had received and reinforced the new ramps with angle iron I moved the wheel wells to match the outside of the tyres and re cut the timbers. (the 6" aluminium ramps supplied were no good as I had set the ramp on the 6" plinth so needed 12" )
    The lift raises to just about 72" but sits on its safety lock at 70" so with the plinth gives me a 76" lift. It takes 2000 lbs max weight and can sit on a safety lock at about 12 different heights for safe working. It raises using an electric pump that forces hydraulic fluid into a ram that then uses a chain to hoist the main beam.
    One of the things I liked about this set up is it is very versatile in that it is easy to adjust for varying wheel bases and weights plus it can be mechanically set at almost any height. Hope this answers some of your questions and if you want any ore info or pictures I will do my best to help, regards Rigsby
