Results 1 to 10 of 10
    Default DATE WHEN TIRE WAS MADE
    I have looked for this info because it's been posted but can't find it ..... somewhere on all tires is a code that enables you to figure out when a tire was made ( approximately ) ....... Thanks .... Mike
    Jul 2014
    Mint Hill, NC
    On the sidewall of the tire at the end of the DOT information there is an oval with a four digit number in it.The first two digits identiify the week and the second two digits identify the year.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    This help?
    https://www.tirebuyer.com/education/...-of-your-tires
    Feb 2012
    Spring City,Utah
    It is prefaced by DOT
    This URL may help you in your quest
    https://www.tirerack.com/tires/tiret...170817004507:s
    Looks like we all went to the same place at about the same time.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jul 2017
    Huntsville Alabama
    Better 3 simultaneous replies than none
    Jul 2014
    Mint Hill, NC
    I owe the information to SpyderAnn who explained it to me specifically concerning the last date for the soft rear tire compound on the 2014 RTs. Any tire with a date later than 2814 was one that had the old, harder compound that was brought back when so many owners complained about very short rear tire life in the new tire compound.
    Cognac 2014 RT-S
    Default AGE OF THE PIRELLI TIRE I JUST BOUGHT
    Thanks to all you CODE breakers out there .... the tire was made in late Apr. of 2014 .... so it's 3 yrs. & 4 mos. old .....yes getting very close to an age that would give me concern, but it's probably going on shortly ...... Mike
    Dec 2013
    5 years old isn't too bad for a tire - here in Oz anything up to 7 years old is still legally able to be sold as 'new' (as long as it's unused! ) but after that, it's a no go!
    We also 'allow' tires up to 10 years old with sufficient tread depth to be classed as 'roadworthy' without necessarily requiring further 'testing' to confirm it's adequate, altho some authorities have been known to just use a swift kick as the 'further testing'!
    Still, it's probably a good thing to get on with using that Pirelli - I mean, we all want to know what you think of it for your Spyder, & how can we find out unless you do some miles on it!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jun 2014
    ny
    There will be dot on both sides, one side of the tire has 12 digits, the last 4 are the week & year of production
    Default DATE OF TIRE
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Thanks , and that's how I arrived at the date I posted above in my last post April of 2014 ............... to answer Peter's Post , you know I know tires ... so you know I didn't buy this one on a " whim "Mike
