Burning Rubber Smell
My 2016 Spyder F3-T has about 1300 miles on it. After a ride, when I park it in the garage, I get what smells like burning rubber. Not too strong, but definitely noticeable. I thought maybe it was just "newness" burning off. I am wondering if the belt is misaligned, but I don't see any fraying on the edges. Any ideas or thoughts??
Spyder Deb has a similar issue but is usually caused by rapid wrist motion on the throttle
Sorry to interrupt your thread. ..
Wayne
pauly1 - SpyderDeb's 'wrench'
2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
IBA #48220 SS1000 BB1500
2015 F3-S , OEM na Basic Black with Custom Wrap
Interesting. ...🤔
Do you have a female companion with heels melting on the pipe... have seen that a few times. But you would have to sniff it out like a hound dog. You may have to remove some plastic and see if there is anything loose and close to the pipes. But if not major give it some time if it gets worse have it checked out. Belt would not do that has to be more on the rubber (hoses, wiring etc) hitting the pipes. You could have picked something up like a plastic bag and it is stuck to the manifold....
2012 RS sm5
How's the belt alignment on your rear sprocket???????? If there is NO gap(1-2 credit cards) the belt could be rubbing the flange giving you the burning smell. It also makes the inner rear wheel dirty.
Mike
2021 Marsala Red Metallic RT Limited
I get the same burning smell on my F3s. I noticed my belt does touch the inner sprocket flange and my inner rear wheel gets dirty. I'll have to adjust the belt alignment one of these days.
2020 CAN-AM Spyder F3-S Special Series (sold)
2022 CAN-AM Ryker Rally 900
My RT did this when I got it. It still does but not as bad now.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
Burning smell as well.
Hello All!
I'm a newbie to spyders and to forums, so bear with me. About 6 weeks ago I purchased an F3-T with 3700 miles on it and also noticed the burning smell of rubber. I have put over 3000 miles on (can you tell I love it ) and still get the odor every now and then, but no other symptoms. I've just been waiting it out, but not sure that is the answer.
Originally Posted by Joel The Biker
It is actually road dirt and debri that get thrown onto the hot Catilytic converter under the bike. I have solved this by wrapping my cat in heat sheilding. You could also do a cat delete and the smell will go away. Its not the belt or the tire. Nothing to really worry about.
You don't KNOW that without being there.
There can be several causes, most of which are "normal" but some might require attention.
And I don't think the wrap you put on the CAT is a good idea either.
They are designed to get quite HOT but your insulation might cause it to get way TOO hot and cause a problem.
Usually they NEED to have some ventilation.
As for the OP, I noticed that the first couple of rides with mine but now it's gone away, as far as I can tell so I figure mine was just things "burning in" from being new. If it continues, I think you should go for a nice fairly long ride that ends at the dealership so one of their mechanics can give it a quick sniff and look while the smell is present.
My bike has over 13,000 miles and it still smells of burning rubber when I put it my garage. Nothing wrong with it, no issues at all.
YEP I AGREE
Rubber Smell comes front sprocket!!!
I 'm pretty sure the rubber smell odor comes from the front sprocket...Could you checked it on your bike ?
Originally Posted by hillrad
Sorry can't resist. "Burning rubber smell" reminds me of the 80yr old fellow that went to the brothel and as they were handing out free "protection" the old man said "no thanks... can't stand the smell of burning rubber"
good one
No problem
I took the Spyder in for some work. Tech says that the smell is not a problem. Everything checks out OK. It may be some of the protective coating they apply to the pipes burning off. It seems to have diminished some, so I am not going to worry about it.
I also experience a burning rubber smell from time to time from my F3-S
However, it's self induced I'm afraid.
Just another crappy day in Paradise....Aloha!
Burning smell, me too
2016 F3T SM6, (2700 miles) I washed my bike a few weeks back and since then I can smell the burning rubber. Before that did not have any issue. Might be an coincidence. Did not power-wash, just used a garden hose. Not sure if its a real issue or like other's have done do I have to just wait it off or get used to it?
Might be another feature.
My Daytona had that initially, but as the miles mounted it has went away for the most part. Belt is correctly aligned 2-3 mm away from rear flange. Working on 17k now.
I believe its coming off the cat my stopped smelling like rubber after a ride when I removed the cat
I have a 2017 F3T with about 2000 miles on it that has this issue too. My mechanic says it will eventually go away.
I had over 20K on mine and the rubber smell never went away until the cat was removed.
check your underwear just in case
Good Idea!
My 2016 RTS still smells after riding, have 4K miles on it now. Didn't think of the Cat!
Steve
Not unusual
I ride a 2015 F3-S with 4,500 miles on it. I often smell burning rubber when I park it in my garage after a run. I don't think there is anything wrong with the Spyder and think the smell comes from the rear tyre due to my too frisky use of the throttle on the way home. mmmmmm.
Please don't lead me into temptation, I already know the way. I can resist everything except temptation.
Thanks. I have only rode my Spyder three times so far, but I got that smell 2 out 3 times. That explains why.
