Results 1 to 8 of 8
Thread: Blanking caps
    Active Member Black Pig's Avatar
    Glasgow, Scotland
    Default Blanking caps
    On the tanks, either side of the ignition switch, there are two blank caps. Anyone know what they are for? (F3 Std)
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Smile
    Quote Originally Posted by Black Pig View Post
    Yes, the left side for heated grip and the right for driving light switch.
    2016 F3L , Big Bike Parts Black
    Glasgow, Scotland
    Ah, thanks for that, next question, where are the driving lights fitted and do you know where the connector for the heated grip is located?
    I do have a workshop manual but have got nowhere with the location of connectors on it.
    Mar 2015
    NE Kansas
    The right side blanks are for fog lights. There should be blanks up front and slightly below and outward from your headlights. The bikes comes pre-wired from BRP so you should be able to install both them and the heated grips yourself. Lamonster Garage has a video showing the install process.
    Glasgow, Scotland
    IMG_20170702_103306.jpgDo you mean these?
    They are fitted as dipped headlamps in th UK, which means I *should* have a spare cable way. Winner!
    Glasgow, Scotland
    Anyone know where the heated grips connector is?
    NorCal - Northbay
    Here are the install instructions if it helps:
    http://instructions.brp.com/content/...mber=219400509
    Chuck
    Glasgow, Scotland
    Quote Originally Posted by hypurone View Post
    Cheers.
