fix a flat
hello,
Just curious since we don't have any spare tires does anyone carry a can of fix a flat or something similar in case they get a flat tire and you just happen to be 30 or whatever miles from civilization. I was thinking about picking on up just in case.
Jim
2012 Can am Spyder RT Limited
2013 Chevy Camaro SS
Flat
2010 RTSM5
Do it
Originally Posted by heyharris1
hello,
Jim
I carry a can of fix a flat ( with a tube on it to get to the rear tire ) ,a tire plug set, and Lamonster air pump.
Leon
2022 marsala red RTL
AND
2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
(Onboard) Lamonster Garage air compressor and intelliboost charger.
I carry a easy to use patch kit and Lamont's compressor. My tire buddies really get upset when people put gunk in their tires, but I also understand why you would do it....I believe my patch kit is a Stop n Go....
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
hello,
Jim
I carry a can of it for emergencies, but I know how much it will gunk up your rims and inside of tire. Better than being stranded I guess. I'll carry it until I get a simple motorcycle plug kit and Lamonster's air pump.
I carry a small vulcanizing kit and a small bicycle air pump. I've never had a need for it in 30+ years of riding but I feel warm and fuzzy knowing its there.
Good old string plugs, small tube of rubber cement, and a mini compressor. Used them four times in the last 6 years and they never failed me. Also used them to bail out my buddy when his high tech repair kit with rubber plugs and CO-2 cartridges proved to be worthless.
I carry a plug kit and compressor.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
plug kit and Lamonster compressor
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Agree...
I carry a mushroom plug kit and air supply. Better to have it and never use it than not have it and need it. Also comes in handy for those that don't have anything with them...
2012 RS sm5
I carry a tire plug kit and CO2 cartridges to air up the tire. like this. Takes up VERY little room.
http://www.motosport.com/product/?ad...segment=badger
Originally Posted by Fatcycledaddy
I also carry a "Stop& Go " kit.
Seeing that is what I have but have never had to use, how did it prove worthless? What didn't work? It has a 4.9 out of 5 star rating.
But of Course ! (said with Dracula's accent)
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
I have the same kit.
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
howdy,
You all have thrown out some great ideas. The only problem I see with the co2 cartridges is you are limited to the air only they contain. If something goes wrong with 1 or 2 cartridges is there enough air. I was thinking with a small air pump, you air is limitless. I don't know maybe you can fill up the tire multiple times with the same cartridge but if you need all of them for 1 fill up???
Jim
howdy,
Jim
I carry both the co2 cartridges (they came with my tyre repair kit) and a small air pump. I check my tyres and pressures each morning when on a ride so the pump comes in useful then. The CO2 cartridges will be used when I do get a puncture, if they don't work fully then I'll have the pump to top up.
My assumption, and it just an assumption, is that the CO2 cartridges fill the tyre quickly. If your at the side of a main road you want something that fills the tyre as fast as possible, even if it's not fully inflated, so you can move somewhere safer. The pump I have would take a few minutes as it's small.
Buddy had a rather wide 190 rear tire on his Triumph. 6 CO-2 cartridges took it to 16 PSI. That put it just above "still flat" and no way was this loaded touring bike going to be ridden. Not saying they won't work, just don't put much trust in what four or five will do. Plug held okay, but find another source for air.
We carry a plug kit and Lamontser's air compressor! It's a great little compressor that doesn't take up much room and is PERFECT for airing up the rear tire with the hard to reach valve stem.
http://www.lamonstergarage.com/lamon...r-pack-silver/
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
Plug kit and Aerostitch compressor. Joe seems to be a nail magnet on his various motorcycles so we have used it several times. I use the compressor whenever I need to add air and don't want to pull out our big compressor.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
Rubber cement
My brother rode his BMW to Alaska last year and got a flat rear tire. No problem, he had a plug kit and compressor. But the rubber cement was hard, no good, stranded. I've had this happen to me before. I bought a big tube of the stuff at Wal-mart. Those tiny tubes you get in plug kits just don't last.
So all you readers, check your rubber cement tubes!
Chuck
I just picked up this kit. Looks very good from the reviews and the Youtube info.
I used to use the rope versions with cement. But the ropes always turned gummy and a PITA to use in the summer months. And the cement was a one time use, due to the fact that the cement would harden up by the time I needed to use it again.
If I ever need to use it, I will do a review on it. I already had a compressor so I just got the kit w/o compressor.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
i do
carry a slime kit with compressor
Improvise, Adapt, Overcome, Semper Fi
2020 RT
Limited heated seats
removable back rest & rack
XK Glow light
Paint with light painted panels
(Gone but not forgotten ) 2009 RS SE5
