Results 1 to 17 of 17
    Nov 2016
    Ponchatoula, LA
    Default Foam Grip Question
    OK, so maybe I am picking nits here, but I was wondering if anyone has been able to make a direct comparison between two sources for foam grips for the Can-Am Spyders F3 series.
    One is from Lamonster Garage (http://www.lamonstergarage.com/foam-grip-covers/). The blurb claims they are 50% thinner and don't feel so large in the hands compared to others. I don't have heated grips, so that is not relevant.
    The other source is Spyderpops (http://spyderpops.com/foam-grips-for-all-spyders/). They actually do look a little thicker in the photos.
    I have bought from both sources and each is top notch. I was wondering if one set of grips might be more comfortable in absorbing vibration or less comfortable do to a larger diameter.
    Thanks for any feedback you can provide.
    Wayne
    Nov 2015
    Myerstown, Pennsylvania
    I got mine from spyderpops and feel they were a big improvement. Haven't purchased anything yet from Lamont but intend to in the future. His cat bypass looks top quality.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Branson, Mo
    Default Got a pair of them free for shipping cost
    I have a pair of foam grips I'll gladly give you to try, just pay shipping. I'd guess $5.00 to ship USPS. Took them off my F3s. They were comfortable but I felt they made the grips feel too large.
    Just PM me if you're interested.
    Branson, Mo
    I have a pair of foam grips I'll gladly &nbsp;give you to try, just pay shipping. I'd guess &nbsp;$5.00 to ship USPS. Took them off my F3s. They were comfortable but I felt they made the grips feel too large.&nbsp;<br><br>Just PM me if you're interested.&nbsp;<br><br>
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by Starrider View Post
    I went with some cheapies from Cycle Gear for $6.99. They are so thick it feels like I am trying to hold onto the wrong end of a baseball bat. Lesson Learned. I am going to get the Lamonster "thinner" ones.
    For the chump change compared to other farkles buy whatever you choose and use the ones that suit you best.
    May 2017
    Mesa, Arid-Zone-A
    I think Lamonster and Spyderpops share a lot of the same items. I bet they are the same from either company.
    Semper Fi
    Member 3WheelBob's Avatar
    Oct 2015
    Atlanta Metro
    Default Love 'em
    Got mine from Spyderpops and love 'em. Have bought other items from Lamonster and all have been top notch too.
    3Wheel Bob
    2015 F3S SE6
    I bought Grip Buddies (a former SL sponsor) for both Spyders. I did not like them when using the heated grips on the 2014--to much heat loss. They worked fine on the 2011. I don't use mine anymore, Linda still uses hers. No vibration issues, just liked the softer feel on the grips.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Personally, I would never use FOAM grips.
    I use neoprene and would recommend that material over foam as being longer lasting and much more rugged.
    Again it comes down to whatever floats your boat!
    AJ
    Quote Originally Posted by wvedec View Post
    Wayne
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Bossier LoUiSiAna
    Wayne
    ST not F3 Well got mine special THANKS to Cindy @TricLed at Spyderfest
    https://www.tricledusa.com/_p/prd1/4...for-all-spyder
    they are lil thick but fit fine even over my lid lox. Have not tested the heat grip (thankfully haven't needed) are quite comfortable I think, fyi my glove size: winter XL , summer L. I can "palm" a basketball if need be,(or full frame pistol dbl stack mag) & I'm hoping that they will fit my Yamaha Roadstar as well & will order some more.
    Danbury Connecticut
    I have grip puppies.
    I actually LIKE the larger grip, that's why I got them.
    They cut down the heat on the handgrips, but I still get enough heat through, so I'm OK with that.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2015
    Canton, Ohio
    I ordered mine from TricLED as well and liked them from the first Ryde on.
    They were thinker without being too large, they absorbed the vibration, the added diameter reduced grip pressure and reduced stress on wrists due to slight carpal tunnel.
    Regarding the heated grips I encountered no real reduction in heat at all. The only immediate negative was I noticed that you have to roll the wrist a little more for throttle, but it took no time to acclimate.
    Joe
    Mar 2015
    Advance, NC
    What he said!
    Apr 2015
    Orangevale Calif
    My choice. A little on the thicker side but great quality and will last forever.
    https://www.foxcreekleather.com/leather-throttle-grips/
    Sep 2016
    LI NY
    I have leather grips, never realized how thin the grips were till put them on. very happy with mine.
    2010 RTSM5 , stock Stock Silver
    Quote Originally Posted by Zip View Post
    I put leather grips on my cruiser. The ones with the streamer foo foos on them. No worry about heat loss, don't have that on the cruiser. Just a little extra bling and comfortable on the hands for the road rides.
