Results 1 to 21 of 21
Thread: DIY Oil Change?
    Sep 2016
    Lewiston , Maine USA
    Default DIY Oil Change?
    I've only had one oil change done on my 2012RT bought used and waited around the dealership while it was done. It seemed from what I could see that quite a lot of the body panels had to be removed to do the oil change. Is this normal? Also I'd like to do my own so is there a video I could watch and refer to so I could in fact do my own? It would have to be one for the "Not So Mechanically Inclined!" Thanks
    Nov 2012
    North Las Vegas, NV
    Here is one video, look more up on you tube.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Default 998 DIY oil change
    Quote Originally Posted by Tomline View Post
    The first time will take a little while but it is not hard. I'm not mechanically inclined but got it done and will do them from now on. The videos will get you through it. Good luck.
    Oct 2014
    Fort Mill, SC
    Default Wrenches
    Be careful. It is very possible that one drain plug will need an Allen wrench and the other a Torx wrench. If you use the wrong wrenches you will strip them and then really have a project on your hands.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Default GOOD ADVISE BELOW
    Quote Originally Posted by Grandpot View Post
    ...... and the best way to avoid this is to use a mirror to look at the plugs ... if you can't get under the bike itself .... annnd I ALWAYS set my ratchet to REMOVE - Before I put it on the plug !!!! ..... Mike
    Feb 2012
    Spring City,Utah
    Others have reported stripping out the holes the allen/torx goes into. If you make sure that you have them fully seated in the hole before you apply pressure you'll be fine. Don't let these warnings scare you off. Watch the videos on youtube ,take your time, and all will go well. It really isn't hard just time consuming. Oh, also your owners manual will also tell you how to change oil and what panels to remove and how to remove them. Go ahead and do it you know you want to .
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    There are the pitfalls of the body panel removal and the worry about stripping out the drain plugs. Some of us braver than others. I am chicken, so have the dealer do all mine.
    It is a learning curve though. Those who do it, don't seem to have a problem or issue after that dreaded first time. Lot's of helpful videos and suggestions from those in the know.
    Member Maddoggie501's Avatar
    Jun 2017
    Albuquerque, NM
    You are correct. Just did my 2016 RT. 45 Torx on main drain bolt and 6mm Allen on the clutch bolt.
    Sep 2016
    clark county indiana
    Default hey tom line
    you have a 2012 r-t is it the s-e 5 or the s-m 5 { clutch on the handle bars } .... I am going to do my s-m 5 soon , will most likely take a lot of panels off to see what might be needing cleaned ... let us know how you faired on the job training
    Active Member Igofshn's Avatar
    Lemoore, Ca
    It isn't difficult. Takes less than an hour. I have a 2010 RT SE5, if you have the SM5, it's bout 15 minutes if the plastic is removed from the bottom. Most leave it off after the first oil change.
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default Do you need to pull both of these plugs for an oil change..?
    Quote Originally Posted by Maddoggie501 View Post
    Just curious because I only have 1600 mi. so far on mine and I too plan on doing my own oil changes (just can't part with $300. for the dealer to do it for me). So you will need to drop both of these plugs for an oil change, is this correct ..?
    thanks
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Active Member 11rtLTD's Avatar
    Mar 2017
    ICT
    Default Yes
    Quote Originally Posted by Dmetcalf View Post
    thanks
    To remove all the oil you will need to remove both oil drain plugs.
    If you only remove one you won't get a full oil change.
    If you have the SE5/SE6 make sure that you replace both filters.
    You can get a complete filter kit right here on Spyder Lovers from Bajaron. He honestly had the best deal that I could find.
    2011 RT limited , BajaRon plugs and custom wires Pearl white
    Houston
    Quote Originally Posted by 11rtLTD View Post
    On the SE6 you only replace the trans filter every 24k or so. Not every oil change like the SE5. The SE6 filter is just over $100.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2013
    Marion, Arkansas
    If your successful in doing your own oil changes and are scared you might strip the drain plugs later during another oil change, many here have changed to the hex head drain plugs. I switched to Gold Plugs during my first oil change. So now you don't have to worry about stripping your drain plugs as a regular box end wrench will get the job done.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Mar 2013
    Marion, Arkansas
    I thought BRP recommends that the trans filter be replaced at 28,000 miles on the 1330 engine with SE6
    Houston
    Quote Originally Posted by Ex-Rocket View Post
    Ok so 28k. That usually does not land on a normal oil change interval anyway. If its going to hit before your next oil change, its time to do it. On mine it was at 25k as I do changes every 5k as they are much easier to keep track of and the oil does not last as long as BRP wishes it would anyway.
    Jun 2017
    Texas
    Default Where do you purchase these gold colored plugs at ..?
    Do you know what size thread these oil drain plugs are ..?
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Houston
    M12 and M14 but the main oil plug on the engine side of the 1330 is a 2 oring special deal, not a normal plug.
    28K service interval and I carry them for less than $100.00 delivered. Not a lot less. But a buck is a buck and most will add tax and shipping!
    Very true....
    Mar 2013
    Marion, Arkansas
    Just go to their website at Goldplugs.com Just enter year, model and engine size and it comes up with what plugs to buy.
    Active Member OKey's Avatar
    Apr 2017
    Davis, Illinois
    I think I'll leave it up to the dealer for my bike.
    2014 RTS Limited , Matt Grey
