Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
Thread: New tires
  1. #26
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default ATTENTION
    Well what's your OPINION on poorly constructed tires that can BARELY support the weight of A Spyder ...... Because that's what you probably have ....a KENDA ................. Mike
    Mike;
    pay no attention to the nay-sayers... i have over 100,000 miles on my various SPYD3RS all with CAR TIRES.... the vast majority of us SPYD3R PEOPLE are riding CAR TIRES, and i've NEVER SEEN, nor HEARD of anyone having an issue with them....
    to each their own... and if some people want to buy the KENDA's and get 1500-2000 miles of wear, that's ok with me... i'm NOT here to tell ANYONE what to buy or use... i just give my HUMBLED OPINION, just like most of us do on this website....
    hope all is well up there in the Green Mountains Mike...
    Dan P
    SPYD3R
  2. #27
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    Default I have
    The Hankook's on the front & Yokohama S-Drive on the rear. Very happy with the combination, I have about 10k miles on the S-Drive and 5k on the Hankooks. Will be using this combination again.
    Ride safe!
    2022 Sea-T0-Sky
  3. #28
    Active Member willey's Avatar
    Jul 2013
    martinsburg,ohio
    Default roadkill
    two things,if you switch the front tires you can't just switch the wheels,because the kendas are directional tires and you can usally buy two car tires for about the price of one kenda from a dealer.its your bike and your money.
  4. #29
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Quote Originally Posted by AllanSpyder View Post
    I have now installed the Toyo Proxes T1R tires back and front and the handling is like day and night compared to Kendas.Allan
    Hi Allan, can you tell me what size T1R you fitted to the front? I can find 225/50/15 for the back (although they are getting scarce) but nothing close to the OEM size for the front - closest being 185/50/15 but not sure they'll clear the fenders.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
  5. #30
    Default 185/50-15 Toyo's
    Quote Originally Posted by monkeyboymorton View Post
    I had those exact tires on my 2014 RT ( with the old style fenders that were shimmed ) and they stuck like GLUE .... actually upset the Nanny way to often ..... Mike
  6. #31
    Active Member greybeard's Avatar
    May 2013
    indianapolis indiana
    Default tires
    .... Well here's some ...... He/She/It doesn't know what they are talking about !!! ... First of all SPYDERS ....CAN'T slip & slide in the Rain or wet ..... the VSS prevents this ....That's why folks can put car tires on their Spyders and pump them up to 40 PSI and live to say " feels fine to me "...... I suspect the REAL reason for this change is SOMEONE contacted BRP and ratted on this dealer , and BRP told the dealer in no in-certain terms if they continue to do this they will be punished.... BRP wants to continue selling those Crappy Kenda's for ....10 X's what they cost to make ....... ( might actually be closer to 15 x's )..... Your welcome , Mike
    I hate to burst your bubble but spyders can slip and slide- I know this for a fact. that being said your answer means to me YOU HAVE NO CREDIBILITY
  7. #32
    Default CREDIBILITY
    Quote Originally Posted by greybeard View Post
    Really .... well there is BIG difference between 6 inches and 6 feet or a complete 360 ........... and guess what ... it matters not one WIT what the CLUELESS think about Me .... Mike
  8. #33
    Sep 2015
    UK
    [QUOTE=BLUEKNIGHT911;1292299]I had those exact tires on my 2014 RT ( with the old style fenders that were shimmed ) and they stuck like GLUE .... actually upset the Nanny way to often ..... Mike [/QUOTE
    Ah thanks for the info.
  9. #34
    Dec 2016
    Somewhere USA
    Barely supporting the weight of a Spyder.......really? (back at you)
  10. #35
    The contentiousness of a good argument over tires is always entertaining!
    But when you finally knock off all of the hyperbole: THAT's when folks will listen to you.
  11. #36
    Active Member Joerolwing's Avatar
    May 2016
    Nashville, TN
    Default Back tire
    I just returned from a 3,324 mile, 20 day trip with a new Michelin Pilot on the rear. I got less than 8,000 on a Kenda. In turning reasonable sharp corners at speed with the Kenda, the Spyder wanted to turn an increasingly tighter circle. This doesn't happen with the Michelin. I use 18 pounds of pressure and have found absolutely no downside to a car tire yet.
  12. #37
    Can't agree more. Dealer has solved my problem--so I can just watch.
    Now what kind of oil is best, and how often should I change it out?
    What octane should I use in my 's?
    When should I change out my battery?
    Active Member Poseidon's Avatar
    Aug 2017
    Chesterfield, VA
    I'm new here, but I'm pretty sure the correct answer is peanut oil and you change it when it is time to fry the turkey.
  14. #39
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Tires
    Quote Originally Posted by Dmartin View Post
    I'm thinking of putting new tires on my F3T . Front I'm thinking Continental contiprocontact 175/55/r15. For the back I'm thinking either Bridgestone B340 or Kumo solis kh-16 or Toyo proxes 4. Any thoughts guys?
    Continentals on front great choice on front back I recommend General Altimax RT 43 215/60/R15
