Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Very Active Member youngers's Avatar
    Sep 2016
    clark county indiana
    Default what is it i say
    this is what I am looking for ------- I saw it in original packaging on line ... this one is listed as a " front wheel hub cover " ------ I had miss stated it bolts on the fender area , it looks like it bolts onto the hub bolt section ... will double check into this idea !
  2. #27
    Sep 2016
    I think this is where the hub covers fit - in the fender bolt holes --- now back too the search
  3. #28
    Active Member Kathy76065's Avatar
    Jun 2017
    Ellis County Texas
    Default ebay hub covers
    I found these on ebay
    Have one to sell? Sell now
    Can Am Spyder Front Wheel Hub Covers
    http://www.ebay.com/itm/Can-Am-Spyde...dZqcax&vxp=mtr
    Quote Originally Posted by youngers View Post
    Rick & Kathy
    Ellis County TX
  4. #29
    Active Member Ryan12's Avatar
    Apr 2017
    Wichita, Kansas
    Default covers
    Quote Originally Posted by Kathy76065 View Post
    That Ebay post says it came off a GS model. I wonder if it will fit an RT???
  5. #30
    Sep 2016
    Quote Originally Posted by Ryan12 View Post
    I looked at the mount situation , I would use only the top 2 hole pattern looks like the lower ones bolt too the actual hub assembly , I do not wish to mess with the alignment area of the tire , but I would think the upper holes would do just fine ... I saw these in the packaging somewhere in the world of internet fun ...
  6. #31
    Oct 2016
    Faribault, MN
    Kathy, I'll let you know... but I believe it does. Ordered. They'll match my swing arm rear covers.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  7. #32
    Mar 2013
    Marion, Arkansas
    I tried to install these on 2012 RTS and they wouldn't fit properly. I think that someone said that one side needs to be shimmed with washers which are not included with the kit.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  8. #33
    Oct 2016
    Faribault, MN
    Ex-Rocket Thanks for the heads up!
    Safe Rides,
    IBA 70020
  9. #34
    Oct 2016
    Faribault, MN
    Default Mounted on my '13 RTL perfectly, no shims needed
    Received and mounted the Can Am Spyder Front Wheel Hub Covers that were listed on EBay.
    A big Thank-you to youngers and Kathy76065, They fit just perfect and make my inner hubs look cleaner than my newish wheels....
    RTL Front Wheel inner hub caps (Medium).jpgRTL Front Wheel inner hub caps 1 (Medium).jpg
    Safe Rides,
    IBA 70020
  10. #35
    Sep 2016
    Default that is great
    glad those do fit I will check on a set myself Lamont ,in another section mentioned that these cover interfere with the shock mounts lower joint , when the wheels are turned this was on the other style cycle , not the r-t ... looks like these fit the r-t just fine
  11. #36
    Oct 2016
    Faribault, MN
    youngers, they mount using the supplied allen headed bolts to replace the stock fender bolts, direct replacement, easy peasy.
    Safe Rides,
    IBA 70020
  12. #37
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    One of my front hub covers popped off on the ride home from the dealer when I bought it. I called the dealer and they shrugged it off and wouldn't warranty it. Honestly, it didn't matter much to me, so I didn't push it and just took the other one off. I've been running it that way for almost 3 years with no ill effects.
    My previous 2008 when bought used didn't have them either, so at the time I never even knew they came with a cover.
    2020 RTL SE6
  13. #38
    Active Member chaz7771931's Avatar
    Sep 2017
    PA
    Default 2010 RT SM5
    looked at mine this morning after seeing this post both are gone, how long can you ride with them missing?
  14. #39
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by chaz7771931 View Post
    As long as the bike lasts. They're just a beauty accessory to hide the axle bolt.
    2020 RTL SE6
  15. #40
    Active Member lewisalice's Avatar
    Oct 2016
    Brooklyn NY
    The part number is 705401100, wheel cap
    Is that the part number for the plastic or metal ones?
