Results 1 to 6 of 6
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Default radio fader changing on its own
    Good morning. Has anyone had a problem with the fader (front/rear) changing it's setting on it's own. I keep it at r3 for the wife and sometimes it goes back to the front and she can't hear. Being diplomatic I just say I wanted to hear her sing. Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Default unknown change
    Not an F-3 but on Rt this happens occasionally and not just with the Fader control ..... I think I may be doing it Accidentally , by hitting the Mode bottom at the wrong time for the wrong reason ...... Mike
    If you "Abort" a start process (turn the key on, but shut things back off before it starts...): they system will revert to it's default settings.
    If you have automatic volume control set: it will also shut that off...
    It gets me ALL of the time!
    Nov 2015
    Tinley Park, Il
    Thanks, Makes sense. Mike
    Jul 2011
    Mitchell, Ontario, Canada
    My experience is the opposite. It's aborting the 20 second shut down that the problem occurs. For example when forgetting to set the parking brake.
    2018 F3 LIMITED
    That one also trips me up...
