Results 1 to 13 of 13
    Oct 2014
    Smithville Texas
    Default F3 GPS instalation
    My wife just picked up her F3 Limited and wants a GPS like her RT had. I see Can am offers a Garmin 590 and the handlebar mount with the wiring harness. Has anyone used the bar mount and installed the harness? Is that a DIY project?
    Nov 2015
    Duluth, GA
    Quote Originally Posted by 1fxstbi View Post
    I have the GPS mount/bar clamp combo from lamonster garage on my 2015 F3-S. Works great and not difficult to install as DIY. I bought the harness separate from garmin, pretty simple, just went straight to the battery with it.
    Mar 2013
    Maumelle, AR
    I initially installed my GPS on my handlebar. I didn't like it and then I tried another installation and I didn't like that. I then bought BRP's mount for the 590 and installed it. It's a pretty easy install and it's just like what I had on my RT Limited.
    2020 RT Limited , Chalk
    Nov 2012
    North Las Vegas, NV
    I put my Tom Tom Rider on the 2016 F3L with a Ram mount ball and bolt from canamspyderaccessories.com and wired to to the customer accessory hookup under the left inspection cover.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Oct 2014
    Smithville Texas
    So are you guys using the OEM wiring harness so the GPS sound comes through the radio speakers? I know my wife would be most happy if it had the same style mount like her RT.
    Mar 2013
    Maumelle, AR
    Yes.
    Active Member Bruiser37's Avatar
    Jun 2016
    Tucson Arizona
    Default F3 GPS
    Save your money and purchase Garmin Zumo 660 around $350 it comes with a motorcycle mount with cables and lots of other extras. A Ram handle bar ball mount required. Power & audio cable needs standard plug that that mates with OEM male plug on rear left side under lower trim panel, easy access. Ask your dealer to show you location of OEM ready GPS plug. It's plug and play from there. I have mating power plugs if you can't get from dealer or find them on line... $4 each.
    If you use expensive spyder center mount & cable GPS faces up and unreadable in daylight. RBNS HOODS is a must but won't do any good on BRP center mount.
    Set the radio input to NAV, adjust volume and GPS commands come through radio speakers.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Oct 2014
    Smithville Texas
    Thanks all for the tips.
    Bruiser, I'll look into the 660 it sounds interesting.
    Active Member hillbillywhisperer's Avatar
    Dec 2016
    Florida
    Quote Originally Posted by Bruiser37 View Post
    Does it come with lifetime maps?
    Dec 2016
    Florida
    Quote Originally Posted by trobbins27 View Post
    I used Lamonster's mount also. I purchased the GPS from GPS City but not sure. $550.00. Came with everything but since I just purchased the bike I had the dealer wire it. It looks like they are like $700.00 now. HOLY CRAPOLA!
    Apr 2012
    Northglenn Colorado
    Quote Originally Posted by hillbillywhisperer View Post
    I am to darn cheap for that. I just purchased a Garmin 2599 and wired the power for it directly to my battery and mount it with ram mount. I don't have Nav in my car so its easy to pop off and use in car when needed. I use Lamonsters Bluetooth receiver to connect with my phone and both my song playlist and GPS sound will come through the radio.
    Jun 2010
    Las Vegas
    Last night I was looking at the install instructions for the BRP mount and wiring and it looks pretty easy on the F3. Of course I can't remember the link to the instructions or I'd share it with you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Nov 2015
    Duluth, GA
    Yes it does. On amazon for $430
