Good evening, I bought a bumpskid in Novemebr but am just installing it due to shoulder surgery. I removed the 4 torx screws (inst said t30 but they were t27). The next step is to remove the oem bump skid. My Spyder is silver matte. I thought the skid you remove is the silver that the 4 screws go thru. That piece after removing the 4 screws is still attatched and goes up to the top of the vents in the front. I know it has to be something simple but what am I not seeing. I called SpyderPops and they called back but I did not have my phone with me. Thanks, Mike
2014 RT Limited Matte Silver,Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars, Will it ever stop--NO
The factory bumpskid is black plastic at the very front of the Spyder. It has a curved edge at the front. It has 2 - 30 Torx and 4 - 27 Torx fasteners in it.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
2010 RT- 622
Thanks for the pic. I'm not as stupid as I thought. I just talked to SpyderPops and it seems my bike does not have the original bump skid on it. At some point someone took it off. Now it makes sense. Thanks again, Mike
Well, I got here done. I did not have to drill 5 and 6 as there were holes there with shorter clips already. Maybe it had a bump skid before as there was no oem skid plate there to start with. To get her high enuf to get the craftsman lift under her I made a small step ramp with one 18" 1X10 and another 12" 1x10 screwed together. Then I put her on 3 cylinder blocks. Mike
Here are pics of holes 5 and 6 with clips and holes already there. I'm thinking that maybe there was a bump skid installed before since there wasn't an oem skid on the bike. Thanks, Mike
