Results 1 to 19 of 19
    Apr 2012
    Arizona
    Default RT Side Pod Storage Case Lock
    I'm having problems opening the left rear side case on my RT. Pull the latch and it won't open unless you use your hand to pry it open while still pulling on the latch with the other hand. Even when prying it open, its difficult and time consuming. Only had the RT one month. Thinking of taking it back to the dealer. Anyone had this problem? Any solutions?
    Try pushing in on the lid as you pull the latch lever...
    Both of my RTs had one side (The left...), that always needed a bit of help.
    If you remove the rear panel from the bike: you can easily get to the adjusters for those latches, and make some adjustments!
    Good luck: please let us know how it all goes!
    Nov 2013
    Oro Valley Arizona
    Silicone spray is your friend. Pretty much works on everything
    Leaves no greasy film/marks either.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Oct 2016
    Normal, Illinois
    Default Side pod latch adjusstment
    I had the same problem with my '14 RT-S. There are adjusting mechanism for the cables that operate the latches for the side luggage. Strangely, they are located behind the rear tupperware panel, beneath the latch release handles. Getting that panel back on after the adjustment is a bit tricky. Good luck.
    Feb 2012
    Spring City,Utah
    For some reason the left side on Spyder RT's seems to be the one that hangs up. If still under warranty have dealer fix it. If not take rear plastic panel off (you tube is your friend) and clean, adj and spray with silicon lube spray. Do not use WD40 as it will attract dirt.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2010
    Las Vegas
    The left one is the problem one for me too. I wonder why that is.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2015
    Saint Michael, MN
    I'll join the club and say the left one I have to give a push once in a while depending on the temp. I notice a lot of people open the left side with a slight push. Since I have observed others with the same issue, no biggy to me. Give it a push and it opens every time. When the weather cools, I usually don't have the issue. Just one of the little quirks, I guess.
    Gunner
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    the latch mechanism cable needs adjusting.
    They stretch immediately upon leaving the showroom, and can leave you hanging
    at the darndest time.
    If your dealer is close, and it's a warranty deal,take it to 'em
    It is not hard to adjust youirself, with only minor Tupperware removal.
    if I can do it...?
    when adjusting the one, you better go ahead and do the other.
    Of COURSE we all use the left bag more often, so it stretches first.
    I used to pound and pry too, but then reached "enlightenment"
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by SpyderAnn01 View Post
    The Left is always a problem!
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Removing the rear panel...
    There are 8 screws that hold it in place: open up both saddlebags (), and you'll see four of them: two on each side. The other four are visible when you open the top trunk (Leave the two in the middle alone: they hold the latch!)
    Once they're all out, the FUN begins! It takes some wiggling, jiggling bending, praying, cussing, and sweating... but you WILL be able to get the ends down by the passenger grab rails out and around. It helps to have a friend with some extra eyes and hands!
    Oh! There are two little tabs on the bottom edge of the panel: try to not bust them off! (If you do: it's not a big problem; it's more of an aggravation!)
    Once the panel is off; you can clearly see the adjustments. Take your time, and only do it once!
    Nailing everything back together is actually more stressful...
    Getting the panel tucked back down into the saddlebags is only half of the stress: the rest shows up if the center of the panel doesn't get fully tucked back into place.
    There's a tab on the underside of the solid parts, and it needs to fit into a tiny slot in the panel. Everything will bolt back together perfectly, and the latch will NOT lock, if that little bit of alignment isn't right...
    Good Luck! Let us know how everything goes!
    Active Member Bruiser37's Avatar
    Jun 2016
    Tucson Arizona
    Default F3-T left side case latch
    Quote Originally Posted by Snoop View Post
    Since new had problem closing left side case had to press down on top of case and push shut. Noticed latch hinge pin was backing out should have taken back to dealer when first purchased new but it's been over a year now and will probably have to pay big $ for repair that would have been a warranty fix when first noticed.
    2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    Maybe the assembly guy was right handed????????? LOL
    BIG F
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Removing the rear panel
    Along with Bob's instructions you can find a YouTube video that shows you how to remove the rear panel. It is as follows:
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Dec 2015
    Oakley Utah
    • Removing the rear panel...There are 8 screws that hold it in place: open up both saddlebags, and you'll see four of them: two on each side. The other four are visible when you open the top trunk (Leave the two in the middle alone: they hold the latch!)
    • Once they're all out, the FUN begins! It takes some wiggling, jiggling bending, praying, cussing, and sweating... but you WILL be able to get the ends down by the passenger grab rails out and around. It helps to have a friend with some extra eyes and hands! Oh! There are two little tabs on the bottom edge of the panel: try to not bust them off! (If you do: it's not a big problem; it's more of an aggravation!)
    • Once the panel is off; you can clearly see the adjustments. Take your time, and only do it once!
    • Nailing everything back together is actually more stressful...Getting the panel tucked back down into the saddlebags is only half of the stress: the rest shows up if the center of the panel doesn't get fully tucked back into place. There's a tab on the underside of the solid parts, and it needs to fit into a tiny slot in the panel. Everything will bolt back together perfectly, and the latch will NOT lock, if that little bit of alignment isn't right...
    Useful. Thanks.
    2014 RTL Platinum
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    Anyone repaiced the backup and turn signal lamps to LED's on there 2014+ RT's? If so what number LED did you use for them.
    Active Member C3517C's Avatar
    Jul 2009
    Las Vegas, NV
    I had the same problem on my RT. It turned out that the cable was frayed. If the adjustment doesn't fix it check your cable from front to back.
    Jun 2020
    St Augustine F
    Presently, I am having a problen with my 2017. I cannot see where the adjuster is. Can someone show a good [hoto
    Vermont
    I also had the same problem on my RT( 2014RTS-SE6), in 2017.
    I have not had the problem since than.
    I change the headlights/fog lights to LED's.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Sep 2012
    Stetson, Maine
    Left side, problem child. Adjusted, works good now.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
