jacking points for a spyder rt limited 2016
I was wandering how I can lift up my 2016 rt to change the oil a little easier with a motorcycle jack?
If you're talking the Motorcycle ATV style jack, keep the back rail forward of the end of the center frame end (usually in line with the Front footrest/pegs.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Let's see....
20150630_123305.jpg adjust to your model to lift balanced. If on A stands one under each A arm joint by the wheels in front and one under the rear shock. Use a piece of 2x4 to span the mount...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
SpyderLovers Sponsor
Jack stands
I put them under A arms every day. No harm, no foul, no damage. Go ahead, it will be fine.
Joe Meyer
If you can put a jack stand under the A arms doesn't that also imply that you can jack it up there (to change a tire, for instance)?
That's helpful. Unsure what you mean by using a 2x4 to span the mount...can you elaborate? Thanks.
2014 RTL Platinum
