Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Feb 2017
    Quote Originally Posted by almosthere View Post
    250000843, 250300039, 708300383, and 708300384 Are the part #s to order. For all the nuts bolts and strut you'll need.
    Your solution interests me because my wife's new-to-her RT Limited came with the same trunk rack. I like to contribute to her happiness, so . . . I started researching the parts numbers and here's what I came up with (from PartsShark as I recall). The info is from the exploded parts drawing.
    Item 11 - Ball Head Stud (what a great part name!) - part # 250300039 @ $5.99 - one required
    Item 12 - M8 Flanged Nut - part # 233281414 @ $1.99 - one required
    Item 30 - Gas Shock - part # 708300383 @ $59.99 - one required
    Item 31 - Spacer - part # 708300384 @ $10.99 - one required
    Item 32 - Torx screw, M6 x 30 - part # 250000398 @ $1.99 - one required
    Item 33 - Domed Nut, M6 - part # 232361493 @ $1.99 - one required
    So, if all the necessary bits are OEM items, and I haven't made any mistakes in transcribing part numbers or prices, the cost appears to be right at $83US - plus tax and shipping. Not cheap, but in the grand scheme of things not outrageous either.
  2. #27
    Feb 2017
    So, before I tear into it, does anyone have any advice on removing the passenger back rest on the RT to get at the trunk lid struts?
    I'll wager there's a You Tube video that shows how to do just that. Thought I haven't looked, there's a high probability that there will be - it seems there's a video about how to do almost anything to a Spyder.
  3. #28
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Arion View Post
    That looks about right. The original parts list left out the two nuts (item 12 and 33) so I'm going to have to source those locally before completing the install.
    2014 RTL Platinum
  4. #29
    Dec 2015
    Oakley Utah
    I didn't find a video but found this earlier post from Firefly;
    Remove 3 Torx from inside the rear trunk, then 2 smaller torx up above holding the plastic 'top' in place just need to be loosened.. then the whole thing will just slide up and out....
    2014 RTL Platinum
  5. #30
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    See Rear Tote Rack posting on todays GNERAL DISCUSSION. It won't help UtahPete's problem, but could save you a lot of grief.
  6. #31
    Northern Kalifornia
    Do you remember which spring it is?
    After you remove the strut, unscrew the end off the rod and take it all down to your local ACE Hardware store. In the fastener department there will be a bunch of drawers with coil springs. Go through them and pick one that will go over the rod but not over the not the large portion of the strut. When I found one I had to adjust it a little by stretching it a bit so it would apply a little more pressure to hold the lid up. It's a hand fit process, but it works very well when you get it all together. A new strut is kind of expensive.
  7. #32
    Dec 2015
    Oakley Utah
    Thanks. Sounds like a great alternative to the new / additional strut.
    2014 RTL Platinum
  8. #33
    Dec 2015
    Oakley Utah
    Here's what it looks like with the passenger seat back removed (3 large and 2 small torx screws on the face of the trunk)
    2014 RTL Platinum
  9. #34
    Feb 2017
    Well rats! I was virtually certain there would be a video. Just goes to show how wrong I can be (very rarely however).
  10. #35
    Dec 2015
    Oakley Utah
    Not saying there isn't one ... I just didn't look any more once I got the info I was looking for. It really is very simple - 5 torx screws accessible from the trunk and you're done.
    2014 RTL Platinum
  11. #36
    Dec 2015
    Oakley Utah
    This worked really well. See adjacent pic.Trunk lid strut spring-2.jpg $1.00 fix for my less-than-spry trunk lid lift strut.
    2014 RTL Platinum
  12. #37
    Northern Kalifornia
    Thanks to Finless, he came up with the idea.
  13. #38
    Feb 2017
    Man, I love simple fixes. Well done!
  14. #39
    Aug 2010
    Newberg, Or.
    Please see todays posting: "TO MODIFY OR NOT TO MODIFY"
