I had the same problem but when I shifted into 4th gear the problem was the GPS Gear Position Sensor after I changed it problems gone
Yup!
The gear position sensor is getting a bit wonky...
I agree, gear position sensor.
Same agreement here... we had to replace the gear position sensor on both of our 2011 RTS's.
It is a cheap plastic part that seems to wear easily. I wish someone (Lamont. ..JT...) would make a metal replacement part...
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Some more questions if it is not an abuse.
Is it easy to change?
Do you know the part number?
Is it very expensive?
Thank you.
