Results 1 to 15 of 15
    May 2017
    Gibson City,Il, USA
    Default Antenna for a rear box
    I have a f3-t. I am considering installing a box on the rear cargo rack that I recently installed. The radio antenna is in the way. Does the manufacture or anyone else make an adapter so that I can relocate the antenna to the box?
    Default WELLLLLLL NOW THAT YOU MENTION IT
    Quote Originally Posted by gibsonman View Post
    .. After I broke the oem ant on my RT I replaced it with a fully retractable auto antennae .... I think the reception improved ...... got it on E-bay .......... Mike
    May 2017
    Gibson City,Il, USA
    Is it just a standard auto antenna?
    Default ANTENNA
    ..It was either Bosch or a Sochee (?) just an ordinary manual collapsible Antenna.... extended it is about 40 inches , you do need 9 inches under the upper mounting seal ..... Mike
    Dec 2015
    Oakley Utah
    Mike, I broke my antenna on this last trip (from putting the cover on and off I think). So, now I'm looking into options to replace it and came across this thread. Was that an RT you installed yours on? You mention 9" clearance below the grommet; did you have to change anything to install that disappearing antenna?
    Thanks.
    2014 RTL Platinum
    Active Member rays hell's Avatar
    Hiram Ga.
    Default antenna
    I purchased the top case separately and it came with the antenna ground cable and a cable harness for lights, cargo latch, usb power outlet and antenna extension. You have to drill new holes in the case to relocate the antenna.
    I just took mine loose at the mount and laid it down flat under the seat because I don't use the radio and was not about to drill holes in my $1200 top case.
    Monique,
    2016 F3t pearl white
    Ultimate driver back rest
    12v power outlet for batt. tender
    Doc Humphries' vibration damper
    factory floorboards
    added topcase
    Active Member Kathy76065's Avatar
    Jun 2017
    Ellis County Texas
    Default Antenna remount
    Quote Originally Posted by rays hell View Post
    YEAH THAT I also mounted a factory top case on my F3T and slid the antenna under both seats for the same reason and it works just as well as it did when exposed.
    Rick & Kathy
    Ellis County TX
    Nov 2013
    Oro Valley Arizona
    Well old Mr. perfect here was trying to put a Harley half cover on and finally snapped the antennae off. I replaced with a shortie off of Ebay. Works well
    for me. I hardly listen to AM/FM. Normally listed to XM through Bluetooth 665 and XM 40 antennae.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Dec 2015
    Oakley Utah
    Quote Originally Posted by jaherbst View Post
    I did the same with a Spyder half-cover, so it has nothing to do with the incompatibility of the brands!
    2014 RTL Platinum
    Hiram Ga.
    Quote Originally Posted by Kathy76065 View Post
    You are absolutely right. I got Spotify and am able to listen offline. No need for a shorty antenna, it won't break under the seat.
    Monique,
    factory floorboards
    added topcase
    Aug 2015
    Crosby,Texas
    Default Antenna
    Thanks for the tip. I did the same with mine. Thanks again
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Yes they do. And very proud of it also. $32! Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    Active Member always young's Avatar
    Oct 2015
    Melbourne, Fl
    Default Antenna with wide top box
    I just installed a larger top box form my C14 (has all of my rally stickers on it) on my 2016 Ltd using the Backer rack. This rack BTW works better than the pictures give it credit. Anyway, since the antenna has a spring base, I just moved it to the side. Everything still works great and the reception if fine.
    Apr 2015
    Green Bay, WI
    Thanks.
    Forget the antenna's that require a metal surface for the magnetic antenna---the round frame doesn't cut it
    Darrell
    Apr 2015
    Green Bay, WI
    I found out my antenna works great if I can get my wife to hold it up high in her right hand
    Darrell
