Results 1 to 5 of 5
Thread: Belt adj
    Apr 2017
    Pittsville Maryland
    Default Belt adj
    How much movement should be in belt after adjustment? 1/4 inch ? Up and down
    Sep 2016
    Alma,Arkansas
    Default Belt Adjustment
    Quote Originally Posted by dsteve931 View Post
    The best way to adjust the belt tension, that I have found, is by using a tension device called the cricket. The cricket, at least the one I have is made by/for Gates tire and rubber. The cricket will establish the correct tension anytime that you want to check. The device is simple and repeatable, I keep one in the tool kit. Cost is around $10-14.00.
    Good Luck
    Larry
    Default Don't know. ..!!
    Rule of thumb is you should not be able to twist the belt 90° . Best is about 45° but the kricket is the way to go. The sonic ones they supposidly use are very pricy..
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    Belt twist is not a good way to go as everyone's twist is different. The Krikit II is by far the best bang for the buck. They are re-branded as Dayco, Gates, etc. But they are all the same.
    Dayco Krikit Tension Gauge - YouTube
    Jul 2017
    Nowhere
    Default Which model of Dayco Krikit?
    When I google this part, they list several model numbers. Which one is the right one?
