Originally Posted by ttrac
Just a quick follow up, on a 2017 RTS the horn is located almost dead center on the a frame. Pull off the skid plate and one small panel and there is the horn. I have no idea why they changed location once again. Once we found the horn it is an easy swap. Hope this helps someone out.
ttrc, thanks for the info. I have a 2018 RT s6 and i'm new at this. Hopefully, it's still in the same location as the 2017. Can you help and be a little more specific when you talk about the skid plate and the small panel? I'm changing the horn and don't want to start pulling plastic if I don't have to. What do you call the skid plate?
Thank you.
okay, this is the "skinny" on the 2017 RT horn location.
Early production models ....horn under LH inspection panel. (like previous years)
LATER production models... on RH side.
Spyder Pops tells us about this in their listing for the Wolo Bad Boy horn.
I just installed a horn in my 2017 and it happened to be on the left.
2017 RTLimited horn location
This is where it's located on my bike.
Mike
From the service manual for a 2018, the horn is located just behind the trunk. Accessible from the bottom.
