Need Help on the Road 622 trailer lights
Hi Everyone, I'm 3 days into a 7 day trip and the brake lights went out on my 622 trailer. The running lights work, but the blinkers are very dim. I have a 2015 RT-S and have done the wiring conversion on the trailer 2 yrs ago, I have put over 1000 miles on the trailer since redoing the wiring and never had any issues. I have checked the fuses in the frunk and they are all good. Unhooked the trailer from the bike and reconnected everything. It almost seems like a ground issue. Does the trailer ground thru the ball and hitch? Is there another fuse hidden somewhere I'm missing?
Any thoughts are greatly appreciated. Thank you in advance for your help
When you did the wiring conversion did you add the grounding harness? That may be your issue. However, when I first converted my 10 RT 622 trailer with my 14 RT all of the lots would go out due to the lack of the grounding harness
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
a loose connection
now some times when wire connections are made , like a 3 wire pin connection , when making the harness , 1 wire usually will not make it too home spot in the harness , or it works itself out of the harness ... give the wires a genital tug ,too see if 1 pulls out too easy ,that will be the problem , when connecting the female connector will push the male connection out of place ... { just a thought }
Originally Posted by youngers
... give the wires a genital tug ,too see if 1 pulls out too easy ....
Owwww!
2014 RTL Platinum
