F3T 2016 Change final belt drive ratio
I read somewhere someone added one tooth to engine drive pulley, expended final gear range (RPM) and found it opened gear/speed range without upsetting the can bus computer system functions. Is such a Spyder drive pulley available? What say anybody with info or experience regarding this mod?
2018 RT Limited Spyder , Garmin Zumo GPS, Battery tender wire harness Show Chrome brake pedal extender Oxford Blue
Little checking..
You can get different size sprokets. cheapcycleparts.com carries the european parts and they have a different size. What I don't know is how much difference and how it will or will not affect the nanny...Computer system....
2012 RS sm5
